GC front blower/blade
/ GC front blower/blade #1
gc2310
Eastern Ontario
MF GC2310 TLB
I'm wondering if anyone has a scan or a PDF of the installation manual for the front blower/blade and quick hitch that I could have a look at. Thanks
/ GC front blower/blade #2
If you could be a bit more specific....?
Installation manual for a 2360 snowblower for a 2005 GC2310TLB. Thank you
/ GC front blower/blade #4
Here are some shots of the MF set-up.
/ GC front blower/blade #6
Simple:
Expensive, but worth every penny if you get a fair amount of snow every year.
Throwing dry snow 40-60 feet is not unusual; wet snow 20-35 feet. Just imagine... no high piles on the edges of driveway; even main road snowplow "leftovers" are not a problem.:D
  • storm 1:27:09-3.JPG
    storm 1:27:09-3.JPG
/ GC front blower/blade #7
We sell 20+ 2360's a year, and have not had a customer that was not happy with the snow blower.
/ GC front blower/blade #8
IJ, how hard is it to install and take off the Quick Tach? I see you have the pieces on dolly's is it difficult to install the blower after Quick Tach is installed?
Rick, my dealer says everything is back ordered. I have the Quick Tach ordered. When do they usually start to ship?
/ GC front blower/blade #10
Of the four attachments/implements I own, the blower is by far the easiest to attach & remove.
With FEL off, I dolly the quick-attach assembly over to the tractor (after grille guard is removed), lift it up and "hang" it on the front frame cross-member, tighten up the large T-handled bolt, then attach the two hydraulic hoses. Last thing to do is add the mid-PTO driveshaft. It goes from the front of the HST to the rear of the quick-attach. This operation takes me about 8 minutes, and I'm pretty slow (careful). It takes longer to remove the grille guard than to put the quick-attach on.
Putting the blower on & off is very easy. You saw the dolly; the front edge of the blower rests a 2x4, to get the right angle. I just slide it up to & onto the shoe, ensuring that the driveshaft stub on the front engages the blower's shaft as I do this. When it's shoved on all the way, pull up on the locking pin lever (on the shoe), secure with a lynch pin, then hook up the flat-four electric connection --that I added-- for the chute. Done.
Since the quick-attach assembly can be left on for FEL use (though it hangs low-- be careful!), removing the blower is only a matter of easing it down onto the dolly/2x4, releasing lynch pin & locking lever, and sliding off, after electric is disconnected. Takes maybe 2 minutes- really! If I'm going to use the FEL, of course, the two blower hydraulic lines are disconnected and tied up out of the way (velcro strap).
Putting the FEL on is another matter, for me at least. I just need more practice!:laughing:
/ GC front blower/blade #11
Thanks, Irving.
/ GC front blower/blade #12
Blackd,
We have the sub frames on back order also, we expect them to start showing up in two or three weeks.
/ GC front blower/blade #13
F.Y.I. other attachments that connects to the quick hitch system are the dozer blades, model 2335 & model 2340 :thumbsup:; and the rotary broom model 2330 :D. KC
2022 EZ-GO ELITE...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2018 JOHN DEERE 60G EXCAVATOR (A64279)
2018 JOHN DEERE...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
MAN BASKET (A64553)
MAN BASKET (A64553)
