GAUGE INSTALL ON JOHN DEERE 3032E
   / GAUGE INSTALL ON JOHN DEERE 3032E
the cost were $15.00 for each gauge plus shipping on ebay .the oil preesure sending unit was at a local marine store for $18 temp sender was $12 plus shipping from surplusunlimted.com the fittings and connectors i spent about $20 and the wire i already had and wire loom i had too.in my previous post i said about $75 but if i had to buy wire and wire loom i would say about $100 for all
   / GAUGE INSTALL ON JOHN DEERE 3032E #12
I know this is an old thread but I just ordered/received the gauges and senders and I have a couple of questions. The water temp send is 3/8" FIP and apparently you used the 3/8" NIP 2 brass nipple and FIP tee for the temp sender (even though the photo doesn't show that?). But looking at the photos it looks like you teed off the oil pressure sender too. What is the diameter and thread size for this sender? Thanks.
   / GAUGE INSTALL ON JOHN DEERE 3032E #13
:welcome: to TBN
Note that slayer has not been active for the last three years, so a suggestion would be to send him a personal message.. a good way to make contact.
Hope you can post some of your work as we like the pics.. and are good inspiration for readers in the future.
   / GAUGE INSTALL ON JOHN DEERE 3032E #14
Thanks for the advice. I'll send a PM. I can figure it out myself, but his knowledge would be helpful. I will definitely post progress and photos when I commence the install. As soon as I get this bathroom painted. :eek:
   / GAUGE INSTALL ON JOHN DEERE 3032E #15
Don't envy you one bit over the "bathroom" task.. Good luck with that.. and hope it doesn't lead to another inside job.. ;)
   / GAUGE INSTALL ON JOHN DEERE 3032E #16
Thanks!! I'm taking today off work in hopes of finishing it. The kitchen is next, but I started these projects so long ago I'm embarrased to say. And my wife has been more than patient. :ashamed:
Looking at slayer's pics it's obvious it's a pre-DPF model. I can barely find anything on my engine because that DPF takes up so much room!! It's gonna be a challenge to do this without removing it!! :mad:
   / GAUGE INSTALL ON JOHN DEERE 3032E #17
Need some help... the "DPF" is ??
   / GAUGE INSTALL ON JOHN DEERE 3032E #19
Thanks.. a reminder not to go there. Maybe EPA will get dumped by then.
The water temp gauge fit in with a reducer in to thermostat housing if I rember right as for oil pressure gauge yes it was a tee to keep the factory oil light .as far as diameter and tread size I honstley don't rember Idid take sending unit with to match up sorry cant be more help
2016 Freightliner Bucket Truck (A55973)
2016 Freightliner...
2006 Mercedes-Benz (A55758)
2006 Mercedes-Benz...
2015 DRAGON 137BBL DOUBLE CONICAL VACUUM TRAILER (A58214)
2015 DRAGON 137BBL...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A56857)
2025 Kivel Fork...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
