Gator Problem
/ Gator Problem #1
S. Shaner
Near Pittsburgh, PA
JD 2720, 2305 (sold) JD 797 Zero Turn, Gator XUV, Gator Compact
Hi.
For the past couple weeks my new, less than a year, 855D Gator has been losing the charge in its battery when sitting for more than a day or two. i figured the battery was the culprit, replaced it, but same issue. something is slowly draining it down when it sits.
Any thoughts?
thanks,
Steve
/ Gator Problem #2
There is really no way to diagnosis this over the internet; however, the gator has several relays which could be sticking in the own position
/ Gator Problem #3
Hook up a light between the battery ground post and the ground cable after it is removed. If the light glows, then there is a short somewhere.
Then you can move wires around to see if you can locate where the short is at, and/or remove some wire couplings to isolate relays and switches to locate the problem.. hopefully.
When the light goes out, you have freed up the drain and can decide the next step for fix or replacement.
/ Gator Problem
Thanks. Good direction. i will follow through later today.
Steve
2020 Ford Fusion Hybrid Sedan (A66738)
2020 Ford Fusion...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
JOHN DEERE 6330 TRACTOR (A65057)
JOHN DEERE 6330...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
