Gator Overheating, fan doesn't come on
   / Gator Overheating, fan doesn't come on #11
Many times there is a thermo-switch on the radiator that turns on a relay that then runs a fan. As stated before, if the water pump is not circulating the hot water, the fan never turns on. So, is your thermostat opening? Is the water pump working? Is the thermo-switch switching? Does the relay work? Does the fan work?
Lots of good questions. I was just hoping to get some info about the way the system is SUPPOSED to work so I would know how to proceed. As I previously mentioned, I thought maybe the fan might supposed to just come on when it starts, because there is ZERO airflow over the radiator from movement.
   / Gator Overheating, fan doesn't come on #13
If I remember, it does not come on until up to temp and then interment after that when needed
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A51243)
JOHN DEERE 975 3...
MAH QUICK ATTACH MAST W/ 48" FORKS (A51242)
MAH QUICK ATTACH...
Case 1150G Crawler Tractor Dozer (A50322)
Case 1150G Crawler...
2011 INTERNATIONAL PROSTAR PREMIUM (A52472)
2011 INTERNATIONAL...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
