Gator Overheating, fan doesn't come on
   / Gator Overheating, fan doesn't come on #11
Many times there is a thermo-switch on the radiator that turns on a relay that then runs a fan. As stated before, if the water pump is not circulating the hot water, the fan never turns on. So, is your thermostat opening? Is the water pump working? Is the thermo-switch switching? Does the relay work? Does the fan work?
Lots of good questions. I was just hoping to get some info about the way the system is SUPPOSED to work so I would know how to proceed. As I previously mentioned, I thought maybe the fan might supposed to just come on when it starts, because there is ZERO airflow over the radiator from movement.
   / Gator Overheating, fan doesn't come on #13
If I remember, it does not come on until up to temp and then interment after that when needed
2001 BOMAG BW141AD-2 SMOOTH DBL DRUM ROLLER (A52707)
2001 BOMAG...
1991 International 4900 Box Truck (A55315)
1991 International...
2007 MACK CXN612 DAYCAB (A55745)
2007 MACK CXN612...
2018 Ford Escape SE AWD SUV (A55853)
2018 Ford Escape...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
SCAN FOR HAULING AND FINANCING INFORMATION (A52705)
SCAN FOR HAULING...
