Oil & Fuel Gator 4x2 transmission
   / Gator 4x2 transmission #1
beenthere
Super Star Member
Southern Wisconsin, USA
JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
Have been getting more and more squealing from braking than what I used to get. Made sure the tranny oil was full on the stick.
Changed out the tranny fluid with new, and took awhile, but the squeal diminished to almost nothing. Takes the Deere low vis oil.
   / Gator 4x2 transmission #2
I've had mine for 11 years and it always squealed.
Mine came with a squeal when bought new in '96 (20 years now.. how time flies). But the last couple three years, the squeal seemed to get worse.. and downright annoying. I think some squeal is built into the design, and was happy that most of it went away with new oil.
This gator has raised 6 grandkids.. and been a real workhorse for me as well.
   / Gator 4x2 transmission #4
Now that's a Gator beenthere:thumbsup:
Getting some creep in forward shift selection when idling the 4x2 gator. Thinking this may be an adjustment needed in the shifting rod connecting to the transmission shifter. Anyone familiar with this problem or a fix?
Has not always done this, and have not boosted the idle setting on the engine. But think it may be part of the gear meshing noise when shifting from neutral to forward. Not so much meshing noise when shifting into reverse.
Deere dealer said the "creep" was in the primary clutch.. not a needed adjustment in the shifter.
So have solved with an initial shift into reverse first, then move into forward.. no gear grinding. Works for me, at the moment. May get worse, and then will follow a plan to remove the clutch and do some cleaning.. Deere doesn't offer parts for the clutch.. but my part man knows what procedure to follow (he has one ;) )
   / Gator 4x2 transmission #7
Thanks for the update, I'm going to try that. My HPX gator sometimes grinds when it won't idle down.
   / Gator 4x2 transmission #8
That roof you have on there is great.
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
Ryobi BS 900 9" Band Saw (A59076)
Ryobi BS 900 9"...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A56435)
2023 Kubota...
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
