Oil & Fuel Gas Tank
   / Gas Tank #21
Speaking of gas tanks, does anyone have recommendations for a new gas tank or way to seal my cap better. My plastic tank leaks at the top where the cap assembly is screwed in and this occurs even though I only fill it about 1/2 way. I have searched the web and not found anything and PT wants around $140 if I recall and what's to say their replacement won't leak the same way. Cork gaskets and other selants have not worked for me. Thanks
   / Gas Tank #22
I have the steel tank in the hood on my pt but my gas cap leaked and I replaced the gasket in it first with a paper looking gasket that didn't work, replaced the gasket with a cork gasket that didn't work either so I got a new gas cap and haven't had trouble since with it. I don't know what the difference was maybe a breather hole or something stopped up but I'm glad it did. When you tighten up the cap give it a little extra torque to see if that helps, I hope this helps.
2017 Green Thumb 58OSN3 8ft Pressure Washer Trailer (A55787)
2017 Green Thumb...
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
2020 DRAGON ESP...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A56435)
2023 Kubota...
2007 NEW HOLLAND B95 BACKHOE (A52709)
2007 NEW HOLLAND...
