Gas Tank Location
/ Gas Tank Location #21
How about a portable arm-crane with a 3-to-1 pulley? Slip the 2x4 into your trailer and hoist up the can, then fuel up with a shaker-siphon.
/ Gas Tank Location #22
I don't have any experience other than observations while shopping, but I do have a preference. Most/all of the Korean made tractors have the same tank assembly on the left under the step up. That contributes to center of gravity. All of the 3 series JD's have the tank high up behind the seat. Orange is under the hood on small tractors whereas the Grand L's are low and to the right. I personally like the low tanks for COG and filling convenience. Some are scared of damage so if heavy off-road is an issue, then you need a different tractor or make a guard for the tank.
how do you get the Korean tractors tanks full? filler neck empties into the bottom half of the tank
(3) Pieces of Poly Pipe (A62679)
(3) Pieces of Poly...
2000 International 4900 Tandem Truck (A66285)
2000 International...
New/Unused Landhonor 60 Gallon Sand Blasting Cabinet (A65583)
New/Unused...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63689)
Dual Tailwheel...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
72"Skid Steer 4 in1Bucket (A62613)
72"Skid Steer 4...
