Gas Proof Plastic Repair Sealant?
   / Gas Proof Plastic Repair Sealant? #1
Snap50
A critter in the yard chewed a small hole in our mower's plastic gas tank and I am hoping to find a repair sealant that will stand up to gasoline.
I am guessing a squirrel because there are scratch marks like they leave sharpening their teeth but unfortunately there is a small perforation in one spot.
The mower if old so finding a replacement tank could be a challenge so patching might be the best first shot at it.
   / Gas Proof Plastic Repair Sealant? #2
Best thing to try would be drain fuel out and heat a piece of metal and press against the area to reform and seal tank. You could also find similar type of plastic and add to hole. Weller 2 heat soldering guns have a tip for working with plastic. Good luck with repair.
SealAll claims to be unaffected by gas.
Any experiences with it?
Perhaps the soldering iron and sealant over it.
   / Gas Proof Plastic Repair Sealant? #5
Squirrel did the same to the corner of the SIL old Sears blower fuel tank and it was NLA. I cut strips off the top of a 5 gallon pail and used them and a small propane torch to rebuild it by melting the tank and strips of plastic together. Wasn't really hard but the melted plastic has absolutely no surface tension at all and 5 degrees over melting it would fall thru but I eventually got it.
   / Gas Proof Plastic Repair Sealant? #6
My Speeco woodsplitter fuel tank was chewed through several years back. I used the flat blade attachment on the soldering gun and welded it using strips of "filler rod" from a old antifreeze jug. It worked great and doesn't leak.
   / Gas Proof Plastic Repair Sealant? #7
Have you seen this type of repair????
willy
   / Gas Proof Plastic Repair Sealant? #8
For the white plastic fuel tanks used on some mowers. A hot glue gun will seal the hole and is not effected by gas.
   / Gas Proof Plastic Repair Sealant? #10
Body shop guys do amazing things with Rapid-Fix!
Check it out!
Good Luck!
HOMEMADE 4' X 4' DEER STAND (A51248)
HOMEMADE 4' X 4'...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
JOHN DEERE 7210R LOT IDENTIFIER 256 (A53084)
JOHN DEERE 7210R...
(INOP) NEW HOLLAND TS6.120 TRACTOR (A51247)
(INOP) NEW HOLLAND...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
