Gas Powered Post Drivers
   / Gas Powered Post Drivers #1
South Louisiana
Kubota L4600 4WD w/loader
Has anyone here used any of these type machines? I have a lot of 3" and smaller pipe along with t-post to drive in the ground and prefer not to use a auger or drive by hand. I have been looking at these post drivers and so far I haven't seen any negative comments, but not sure if I am seeing un-biased information.
No specific order of some of the brands I have looked at;
Rhino
Titan
SkiDril
RediDriver
Please share if you have any info on these machines.
Thank you.
   / Gas Powered Post Drivers #2
You can easily drive the t posts with your bucket. Just use the bottom of the bucket and push them in. Makes it a 2 person job but you have the equipment to do it now.
   / Gas Powered Post Drivers #3
I looked at them on youtube, but I can't justify the cost. They also look really heavy, but I honestly don't know if that's part of what makes them work better, or if it's just me over thinking it.
The Man Saver is the one I'm planning on buying. It runs off of a small air compressor, which I already have, and a small generator, which I already have.
I've tried the front end loader to push in T posts and pipe, but find it difficult to keep it straight, and if you hit something under the surface, the T posts just bend before you know it. I also worry that the person holding the post is in danger if anything goes wrong.
   / Gas Powered Post Drivers #4
I've used a pneumatic driver similar to the one that Eddie's referring to and it worked well. I don't remember what brand/model but it looked a little bit more crude and "home built" than the Rohrer mansaver. I remember it looked a bit hazardous in operation, but the Rohrer looks like all the moving parts are shielded and it looks more "finger safe". It wasn't all that fast, but you could control the pole plumb pretty well as it drove.
I don't have any experience with the gas engine driven ones, but my neighbors and I have considered going in on one for all our t-pole fencing we have. If I bought one, it would be whatever model had a good Honda engine.
   / Gas Powered Post Drivers #5
Search Google for more options. I've seen one powered by a small propane canister on the net and at the time thought it might have been ok. Have no experience with any of them but have put in 1000's of survey bars with a hammer.
Al
   / Gas Powered Post Drivers #6
The safety factor on pushing the t-posts in certainly worries me too. I often do them myself by using the standard man powered t-post tool. Just use one "hit" to have t-post standing in ground. Then come along with the bucket and push the rest of the way in.
It certainly takes longer, but my body is not beat up at the end of the day.
   / Gas Powered Post Drivers #7
I have used a Roeher quite a bit. My SIL used to rep them. They really work great and do not require a large compressor and are under $500 depending on model, buy direct from the manufacturer. http://www.rohrermfg.com/
There are also hydraulic ones out there, using the tractor system, but a lot more expensive.
Ron
   / Gas Powered Post Drivers #8
I have thought about fabbing something up to make the loader drive-in safer. Maybe a short length of pipe large enough in diameter to easily slip over a T-post and bolted to the loader bucket. That would keep the post from slipping to the side.
Anyway, fingers crossed until the closing, my wife and I sold our current place and will likely be doing some fencing on a new place once we find one. Our horses are at the point where wire rope fencing will contain them so the next place will be mostly T-posts with just wooden posts for braced corners. I am going to look into renting some kind of driver since I mostly work solo anyway.
   / Gas Powered Post Drivers #9
Exact project I am working on right now. You can use Wedge-Loc Corner/In-Line Brace - For Life Out Here to do T-Posts for the corners. I am using a 7 footer for the corner and 6 footers the rest of the way around. This is for some somewhat temporary pasture to get the horses home.
Once we start to put in the rest of the fence I want to do wood posts at the corners as well. Wedge loc also makes a product to hang a gate off the T-post. Nothing more than a 10 foot gate. For starters we are doing 6 foot. I can get my tractor through a 6 foot gate. Once we go with wood I will do 10 or 12 foot gates so I can get bigger equipment in if need be.
Our soil is sandy loam/clay so pushing T-post in with bucket is zero issue. Working alone with the bucket is a challenge, but can be overcome. Certainly much easier to work in a pair, but we have to make do with what we have.
We are using Electrobraid for the barrier. It is a bit more pricey than other wire rope, but I like the 25 year warranty.
   / Gas Powered Post Drivers #10
T posts... prefer a backhoe. and a pipe i can catch to top of T post in. the backhoe lets me move back and forth in various direction. to deal with the "bent post" happening, along with keep from bending the post. also lets me just "stab" the T post in by hand. even if T post almost falls over to the ground. i can grab T post with backhoe bucket / pipe end and get it straight.
i have wanted to try a ground rod driver on a T post but never had one around to try when needed a T post put in.
backhoe and ground rod = *meh* it work, but ended up with bending a ground rod and had to pull it out and get a new one put in. ground rod way to long and flex / bent.
i have tried a hammer drill for say using a concrete bit to drill a hole. *meh* did not work.
google
post driver site:tractorbynet.com
then click up on images. there are a few threads of different DIY builds of post drivers that i do remember seeing over the years.
the site:tractorbynet.com only brings stuff back from this website. vs searching all websites.
contact a local rental machinery place. there is a couple places about an hour in each direction, that rents out nearly everything that one could need, from simple hand tools, to trailers and tractors. if memory serves they also have a post driver to rent out. beyond the normal augers ( 1 man, 2 man, 3pt hitch, skid steer)
have seen, shot gun shell like post drivers, to LP units, to air compressor units, to hydrualic units, then extremely expensive units that connect to a backhoe. and pick up off of a trailer level it and sink it into the ground.
not sure if i could deal with the shot gun shells, or LP versions, seem rather expensive waste.
the air compressor units seemed to be nice. just looking at them over internet. looks to be like a standard 2 handle man handled T post driver, but instead of muscle an air cylinder to lift it up, and some valves and a trigger. i would imagine they still weight a descent amount. but still life saver on the muscles and shoulders, upper back, neck.
one of the DIY post drivers here on TBN. had a sledge hammer on a track setup. that raised the weight up and let it come down on post to hammer it in, yes, it looked "old school" but simple enough in design. i want to say the builder was putting in 3" or 4" wood posts with it. maybe same person or another DIY builder doing 6" posts. and i want to say they were not "making the bottom end of post into a point" but straight cut on end, and just hammering them in. i do remember comments of some went in at an angle. (connected to FEL, single person doing) nothing they could do about it, beyond try there best as they could.
Chery 7' 10 Drawer Workbench (Red) (A44502)
Chery 7' 10 Drawer...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A43003)
2017 FREIGHTLINER...
John Deere 4120 (A44501)
John Deere 4120...
2015 FORD F-450 (A45333)
2015 FORD F-450...
264 Gallon IBC Tank With Drain Valve (A42745)
264 Gallon IBC...
SET OF (8) PIPE RACKS (A45046)
SET OF (8) PIPE...
