gas cap stripped
/ gas cap stripped #1
JoelD
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
Actually it is the tank neck that is stripped. it is plastic and was iffy when I bought the tractor a few years ago, now, I can not tighten the cap. Any ideas on how to keep the cap tight?
Obviously trying to avoid replacing the entire tank, seems silly.
Thanks,
Joel
/ gas cap stripped #2
Take some teflon tape and wrap it around the neck. Just make sure none can get in the tank.:thumbsup:
/ gas cap stripped
Thanks for the idea
I'll give it a try I've alwYs got plenty around
Joel
/ gas cap stripped #4
How important is a seal for a diesel tank? Obviously you don't want dust entering the tank. However it seems that evaporation is not as big an issue with diesel as with gasoline (based on personal experience as I've had a quarter jar of open diesel on my work bench for the past year with little evidence of evaporation). I'm sure the EPA would object to extra VOC but I wonder if a closed but unsealed diesel tank would cause any problems for the owner/operator.
/ gas cap stripped #5
Here's a weird idea but I would probably at least try it if it were me.
Sand and clean remaining threads.
Coat thickly with that good grey epoxy stuff.
Coat tank cap inside threads and top thickly with silicone grease.
Carefully/slowly 'screw' cap on trying to catch any existing threads and as much epoxy as possible.
Let it set just enough for the epoxy to firm up a bit, not to harden.
Gently twist cap mostly counter clockwise to make sure it hasn't been epoxied to the tank.
Continue moving cap thru drying process of epoxy for same reason.
Might work.
Mike
/ gas cap stripped
Good point Island, It is mostly the dust I'm concerned about. Not sure how much breathing is done through the cap, not much I'd think? I was thinking about using a plastic bag and eleastic band under the cap to seal out dust.
The apoxy Idea is a good one, something I could test out on something else plastic prior to implementing. It is an interesting idea though, just remake threads using cap as die.
Would be super slick if it worked.
Joel
/ gas cap stripped #7
Jeez Louise do not wrap teflon tape on the filler!
/ gas cap stripped #8
if you do the epoxy glue idea, make sure you get the epoxy for plastic's as some will not do plastic very well, good luck. There is one that car dealers and auto recyclers use just to repair cracked bumpers permanent fix.:)
/ gas cap stripped
Thanks
/ gas cap stripped #10
Another thought:
Home Depot and others sell black rubber stoppers of different diameters. We used them in chemistry years ago. Get a stopper to fit the opening and in the center place a toggle bolt or long bolt with nut and washer. Just snug up the stopper into the filler neck after filling up with fuel. The bolt (handle) makes removal easy. A bit of spit to lube stopper makes it seat nicely
J
/ gas cap stripped #12
Doesn't the tank vent thru the cap? Why else would it have an automotive type clicker cap? If that is the case a stopper or plastic over the filler neck would be a bad idea would it not?
/ gas cap stripped #13
You could always drill a small vent hole in the stopper. FYI: those kind of stoppers are readily available at pool supply stores with the bolt/wing nut already in them.
What is the dealer got to say about this? Aren't those some sort of standard thread where you might be able to "retap" it if you could get a metal cap of the same threads.
/ gas cap stripped #14
I vote for a cork stopper. Mcmaster Carr has them starting on p3725
Edit: OOps you have to buy ten at a time...
/ gas cap stripped #15
No, you're all wrong. The best way is to stog it with a good, large potato.
I like the epoxy idea too. Just don't take a nap while waiting for it to set. If you do, please post the results!
Good luck!
Jon
/ gas cap stripped #16
Its probably worn threads on both sides. Replace the cap and just dont tighten it so much.
larry
PITTSBURG 2R CULTIVATOR FRAME (A64278)
PITTSBURG 2R...
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
JCB 3TS-8T Compact Wheel Loader Skid Steer (A64553)
JCB 3TS-8T Compact...
Location Info Please
2016 JOHN DEER 1600 TURBO SERIES II (A66091)
2016 JOHN DEER...
2020 Bobcat S450 Compact Wheel Loader Skid Steer (A64553)
2020 Bobcat S450...
