Garage lower than house
   / Garage lower than house #1
BobReeves
Platinum Member
Tulsa OK
Ford 3000
Can anyone tell me if there is a code or some other reason all garage floors I see are lower than the house floor? Even houses built on slabs seem to have a step up from the garage into the house.
TIA
Bob
   / Garage lower than house #2
I'm not aware of any codes, but putting the garage floor lower than the house enables you to have taller ceilings in the garage, as well as for some, not such a steep driveway slope from the garage to the street.
   / Garage lower than house #3
Don't remember all the details but there is a section of the building code that states garages need to be lower than the house. The code states how many inches lower but don't recall. The reason is because gasoline can travel from a leaking gas tank directly into the house.
   / Garage lower than house #4
I believe that fumes also will collect near the floor. Having the floor lower in the garage prevents the fumes from entering the house.
   / Garage lower than house #5
In our area I believe 4 inches is required.
   / Garage lower than house #6
A step up of 4" or a 4" curb around the door opening is required here in Central Ohio.
   / Garage lower than house #7
Yes, it has to do with gasoline fumes entering the house. The fumes could travel into the house to appliances with pilot lights. Also could build up in basement areas, etc.. There are also some code issues with water heaters, and other appliances with pilot lights when installed in the garage due to the gasoline fumes.
It is also sometimes called a rat wall(self explaining). /forums/images/graemlins/smile.gif
   / Garage lower than house #8
I never knew the technical reasons behind the code, but I know it sure comes in handy when hosing out the garage...
Thanks Guys, as always I knew you would have the answer.
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
1992 Allegro Bay 32FT Class A Motorhome (A50324)
1992 Allegro Bay...
Swict 66" Bucket (A50121)
Swict 66" Bucket...
