Garage lower than house
   / Garage lower than house #1
BobReeves
Platinum Member
Tulsa OK
Ford 3000
Can anyone tell me if there is a code or some other reason all garage floors I see are lower than the house floor? Even houses built on slabs seem to have a step up from the garage into the house.
TIA
Bob
   / Garage lower than house #2
I'm not aware of any codes, but putting the garage floor lower than the house enables you to have taller ceilings in the garage, as well as for some, not such a steep driveway slope from the garage to the street.
   / Garage lower than house #3
Don't remember all the details but there is a section of the building code that states garages need to be lower than the house. The code states how many inches lower but don't recall. The reason is because gasoline can travel from a leaking gas tank directly into the house.
   / Garage lower than house #4
I believe that fumes also will collect near the floor. Having the floor lower in the garage prevents the fumes from entering the house.
   / Garage lower than house #5
In our area I believe 4 inches is required.
   / Garage lower than house #6
A step up of 4" or a 4" curb around the door opening is required here in Central Ohio.
   / Garage lower than house #7
Yes, it has to do with gasoline fumes entering the house. The fumes could travel into the house to appliances with pilot lights. Also could build up in basement areas, etc.. There are also some code issues with water heaters, and other appliances with pilot lights when installed in the garage due to the gasoline fumes.
It is also sometimes called a rat wall(self explaining). /forums/images/graemlins/smile.gif
   / Garage lower than house #8
I never knew the technical reasons behind the code, but I know it sure comes in handy when hosing out the garage...
Thanks Guys, as always I knew you would have the answer.
Portable Creep Feeder with Gates (A50515)
Portable Creep...
2022 BARFORD TR8048 MOBILE SCREEN (A51242)
2022 BARFORD...
2121 (A51244)
2121 (A51244)
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
Westfield MK130-91 Swing Away Auger (A50514)
Westfield MK130-91...
