Garage hacks, adjustments and annoyances.........
   / Garage hacks, adjustments and annoyances......... #21
So far I went through 10 lbs of rods with it and it's a little more complicated setting the heat then my former Century 250 amp welder, the dial numbers are percentages not the actual amps
Yeah it took me a minute to realize that. I usually start with the selector in the range I want and the dial at 50% and then look at the weld and adjust from there.
I also got all the pieces for the TIG side, torch, foot pedal and regulator. What little I know about TIG welding I learned on a much newer machine with a water-cooled torch but this old gal is good enough for what little I do now.
I worked for a sardine cannery (Stinson Seafood, Beach Cliff Brands, you may have heard of them). They had an old barn on the property literally stuffed to the rafters with all sorts of crapola. Lot of junk, some good spare parts, old equipment, etc. They wanted it cleaned up and I made the them a proposition. I'd do it on my time at no charge and separate the entire contents of that huge 2 story building into 3 piles: Keep It, Trash It, and I'm Taking This Home With Me, No Questions Asked.
They went for it and I spent several weekends sorting stuff. I took home that welder, a Hobart welder, a Hossfeld bender, a big ol' electric forklift (needed batteries and some wiring fixed) and some other odds and ends.
   / Garage hacks, adjustments and annoyances......... #22
You probably wasn't in the market for "a big ol electric forklift",but needed it to get that welder home and in case you ever needed to sweep under it some day.:laughing:
Good deal I like a treasure hunt, one mans junk.............I forgot wasn't Stinsons in Belfast and or are they still in business? Bet there not in the shrimp business........... I dont know if I'll ever use the tig funtion on that Miller Dialarc, but if I happen to get into a treasure hunt and find a tig torch, then I wouldn't mine trying that out, I took the tig class at BIW 10 years ago, didn't pass it but least I did learn how to tig weld, just not ex-ray tig.
   / Garage hacks, adjustments and annoyances......... #24
That will be hard to stop after 40 years of muscle memory, you sure it's not the magnetic north pole twisting my grinding cord...............
Definitely. It's the magnetic north pole. 100% no question.
All the same, what if you try inventing some kind of very ergonomic tool rest, so your work cycle is you pick the tool up, use it, and lay it down again in the rest with a minimum of moving around, and this breaks any habit of muscle memory that might be, you know, amplifying the magnetic north pole effect?
   / Garage hacks, adjustments and annoyances......... #25
Can't rule out Russian interference.
Had my son demonstrate how to open my outta reach doors, used rope and a couple pulleys. Sometimes I have to open both doors to load in or out something.
Swing Door - YouTube
My son got tired of going to a machine shop all the time to make something for his saw mill, last week he said wanted to get a lathe so I chipped in and today it showed up, hope it's worth $3,000.00, will be the next two weeks making a bench for it to find out, wonder how level a lathe bench needs to be................
Resized952020031095134538.jpg Resized952020031095134756.jpg Resized952020031095134908.jpg
   / Garage hacks, adjustments and annoyances......... #29
First thing, the bench needs to be straight and rigid. Then it needs to be level. Emhasis on the straight and rigid. And by the way, congrats on a new tool. The tooling will cost more than the initial purchase in short order.
   / Garage hacks, adjustments and annoyances......... #30
It will be interesting to hear your report after one year. At work, we are a machinery manufacturer and milling is 90% of our work and lathe is 10%. At home I have both a lathe and a milling machine, the lathe gets 90% of the work maintaining tractors, implements, and tools. Enjoy the new toy.
2005 Sterling Acterra Tender Truck (A56435)
2005 Sterling...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2009 IC School Bus (A55973)
2009 IC School Bus...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
John Deere HD300 Sprayer Attachment (A56857)
John Deere HD300...
