Garage floor Needs Help-Alot.
   / Garage floor Needs Help-Alot. #1
cdaigle430
Maine
MF GC2410
I have a 24 foor by 24 foot garage built in the 70s and the floor is all pitted and is bad enough to where dollies have a hard time rolling accross the floor. I was toying with the idea of using epoxy to fill in all the pits but is there a better way?
   / Garage floor Needs Help-Alot. #2
I sold concrete repair products & installed & repaired concrete flooring for many years. Prep is critical, you want to remove any loose concrete, no oil & grease, etc. The pros use a shot-blast machine to prep floors but it would be impractical to use in your case due to size & cost. The next best way is to acid wash the concrete, plenty of suggestions on the internet on how to do this.
I would use a epoxy based repair mortar to repair the worst areas. Look for a product with a primer, you brush this primer into the area to be repaired, then mix the mortar & trowel it into the area to be repaired. Sika & Hilti both make products for this but they are pricy. A one cu. ft. section of this material will set you back a hundred bucks or so. If you use a water based repair material (like plain old concrete or mortar mix) it will dry, shrink & pop out of the repaired areas, you won't be too happy with the results.
Lastly, after repairing the damaged areas I would coat the floor with an epoxy coating (the thicker the better) this will protect all your hard work! (Home Depot & Lowes sell this) I know this sounds like a lot of work but it is cheaper than a whole new concrete floor. Good luck.
   / Garage floor Needs Help-Alot. #3
I epoxied my garage floor 6 years ago. The PO had used the floor as an anvil! So I filled all the holes with WEST System epoxy with colloidal silica mixed in before I painted it. It's what I had on hand. I did this after the whole wash and muriatic acid deal. Didn't know anything about a primer. All the patches are still there. Not a one popped out.
I have a tractor and a motorcycle in there. Oh, and a floor jack w steel wheels. Snowblower w chains on the wheels. Lawnmower. Other stuff..........
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
Deer Gates (A53424)
Deer Gates (A53424)
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2015 Toyota Prius (A53424)
2015 Toyota Prius...
