Garage floor Needs Help-Alot.
   / Garage floor Needs Help-Alot. #1
cdaigle430
Maine
MF GC2410
I have a 24 foor by 24 foot garage built in the 70s and the floor is all pitted and is bad enough to where dollies have a hard time rolling accross the floor. I was toying with the idea of using epoxy to fill in all the pits but is there a better way?
   / Garage floor Needs Help-Alot. #2
I sold concrete repair products & installed & repaired concrete flooring for many years. Prep is critical, you want to remove any loose concrete, no oil & grease, etc. The pros use a shot-blast machine to prep floors but it would be impractical to use in your case due to size & cost. The next best way is to acid wash the concrete, plenty of suggestions on the internet on how to do this.
I would use a epoxy based repair mortar to repair the worst areas. Look for a product with a primer, you brush this primer into the area to be repaired, then mix the mortar & trowel it into the area to be repaired. Sika & Hilti both make products for this but they are pricy. A one cu. ft. section of this material will set you back a hundred bucks or so. If you use a water based repair material (like plain old concrete or mortar mix) it will dry, shrink & pop out of the repaired areas, you won't be too happy with the results.
Lastly, after repairing the damaged areas I would coat the floor with an epoxy coating (the thicker the better) this will protect all your hard work! (Home Depot & Lowes sell this) I know this sounds like a lot of work but it is cheaper than a whole new concrete floor. Good luck.
   / Garage floor Needs Help-Alot. #3
I epoxied my garage floor 6 years ago. The PO had used the floor as an anvil! So I filled all the holes with WEST System epoxy with colloidal silica mixed in before I painted it. It's what I had on hand. I did this after the whole wash and muriatic acid deal. Didn't know anything about a primer. All the patches are still there. Not a one popped out.
I have a tractor and a motorcycle in there. Oh, and a floor jack w steel wheels. Snowblower w chains on the wheels. Lawnmower. Other stuff..........
2008 Featherlite Trailer with generator , VIN # 4FGE853218C108480 generator VIN- 4TCSU18516H185904 (A53422)
2008 Featherlite...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
434669 (A48836)
434669 (A48836)
UNUSED IRANCH 16" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 16"...
