Garage built in hillside sweating
   / Garage built in hillside sweating
Ok after I read these post twice and some three times it looks like the question comes down to vent or not to vent. I'm 100% for sure I will insulate the ceiling and walls. Since I'm doing this and redoing the front of the building so I can put in a insulated garage door I don't see why I should vent. By not venting I'm trying to keep the air inside the same constant temp. Now If I go the vent route I don't see why I would want to insulate. So am I on the right track with my thinking on vent and not insulate or insulate and not vent. Thanks Rick
   / Garage built in hillside sweating #42
My take is that even with insulation, you will end up with some air infiltration. Ventilation will bring the inside temperature up to about the outside temperature and minimize the condensation if you insulate. My take is that you need to insulate and ventilate. If you only do one, either way I think you will still have very high humidity.
The closest relevant experience I have is with a bathroom in my basement. When I bought the house, water would be standing on the tile floor from condensation in the summer. I redid the insulation and vapor barrier on the walls. I took up the tile and added dri-core panels to the floor, and then put flooring over that. I then put in a small heat recovery ventilator (about 60 cfm) to pull air out and introduce outside air into the upstairs of the house. There isn't a hint of condensation now and it doesn't even feel humid. You won't be able to insulate the floor, but if you can cover the walls and ceiling (you need very little thickness because the surface heat transfer will be much lower with anything other than metal) and get some air flow (you don't need the heat recovery) you should see a great improvement.
   / Garage built in hillside sweating #43
Having had similar structures... condensation is a problem when warm outside air is drawn in... unless enough air circulates to equalize... guessing a structure with a side fully open all the time?
The blue board does work as long as carefully installed and with edges and seams sealed.
Think of an old metal ice chest... the insulation was enough to separate the zones.
Some of my neighbors with similar workshops have installed radiant floor heat using solar and backup heat which raises the dew point.
Man I really appreciate everyone's comments but I'm as confused as heck on what to do. Does anybody think by insulating and putting a garage door on for a better seal and running a dehumidifier would work?
I'm not that big on drilling through the top of shelter through all that concrete. It looks like to vent the building I would have to. Maybe hire someone to do it.
Who would you even consider to drill holes in shelter and set up a vent system.?
The way I'm thinking is insulate and dehumidify first. If that doesn't work then add ventilation minus the dehumidify. If that don't work the hel* with it.
   / Garage built in hillside sweating #45
I tend to go for one time permanent fixes as opposed to ongoing ones that require monthly expense month after month.
Running a humidifier here would get expensive at 25 cents a kW
   / Garage built in hillside sweating #46
I'm one for doing things in steps. I am on the side of insulate first and see if that fixes it. Introducing new holes into the structure could introduce new problems like leaks. Think of it this way, if you are core drilling through steel and concrete to put in a vent later, will going through a little spray foam insulation be that big of a deal?
You can core drill through roof for the vent, and put fan on it. You need an inlet for the air to come in core drill another hole opposite it and plumb it down to close to he floor for the air to come in . Tom
When I redo the front wall of storage I can run 4" PVC pipe to do this. On one side I can run the length of the building at the top with four T's and on the other side I can run a duplicate pipe on the bottom. No drilling thru concrete at all. Figure out a way to use an exhaust fan with top pipe and I think it will work.
   / Garage built in hillside sweating #48
Sounds like you almost have the same situation as a damp crawl space. Some of the local outfits advertise spray foam to create a conditioned air space.
   / Garage built in hillside sweating #49
Maybe just live with it for a year first. You already know how "venting" it works by opening the doors up on a warm humid day. Call the previous owner and ask him your questions and see what he says.
   / Garage built in hillside sweating #50
No expert here, but thinking about the venting and air exchange. If the outside air is warmer than the "cave space" won't it still condense on surfaces that are colder than the air?
2015 Kubota RTV-X1100C (A52748)
2015 Kubota...
17801 (A51694)
17801 (A51694)
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
2015 FORD E350 16FT BOX TRUCK (A52576)
2015 FORD E350...
