Game Food Plots ~~ Suggested Implements & Attachments
   / Game Food Plots ~~ Suggested Implements & Attachments #1
jeff9366
Super Star Member
Alachua County, North-Central Florida
Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Researching a disc harrow for a 4,000 pound tractor with HST, 4-WD and 45-horsepower for creating small food plots. Is there a rule of thumb for hp/size of harrow? Red iron clay soil.
Cutting unbroken ground for food plots requires a Disc Harrow with pans at least 20" in diameter, which yields ~~ 50 pounds of pressure ~~ on each pan.
Twenty-two inch pan diameter better. If your rear tires are filled with fluid you will be glad pulling twenty-two inch diameter pans.
Scalloped pans front and rear cut unbroken ground much better than smooth pans.
Nine inch spacing between pans penetrates somewhat better than seven inch spacing between pans.
Nine inch spacing between pans allows 5" to 7" surface rocks to pass between angled pans.
Seven inch spacing between pans penetrates soil less but leaves a somewhat smoother output.
Disc Harrow width should be no wider than your rear tires for food plots, preferably slightly narrower, for maneuverability moving forward and in reverse. You need to pass between trees with both the tractor and implement, with tractor potentially turning a bit. Hanging up a Disc Harrow between trees on a slope can be miserable.
MORE: https://www.tractorbynet.com/forums...ing-three-point-hitch-mounted.html?highlight=
   / Game Food Plots ~~ Suggested Implements & Attachments #2
IMHO;with the smaller tractors that most on this site have;a roto-tiller would work much better than a disc.We do 20+ acres a year.
On broken ground;we also use a spring tooth cultivator(with large peanut shares) as a secondary tillage tool;it's fast and fairly inexpensive.
   / Game Food Plots ~~ Suggested Implements & Attachments #3
I have and use a 48" tiller for first ground breaking and then a de-thatcher for later re-working the broken ground. My ground is also flat and fairly light (sandy) so the de-thatcher does a good job.
   / Game Food Plots ~~ Suggested Implements & Attachments #4
I used to disc - no more. Learn about the Burn, Mow and Throw or No Till method. No ground work, just burn it (burn of Roundup), mow and then throw. The old vegitation covers and protects the seed.
I never had any luck with a food plot until I did this and now I have 4 food plots that look fantastic.
Here's an excellent video discussing it: Easy No-till Food Plots -- QDMA Whitetail Weekend Seminar - YouTube
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2020 Chevrolet...
Online Buyers Premium (A55272)
Online Buyers...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
2023 Chevrolet Mechanic Truck (A55973)
2023 Chevrolet...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
