jeff9366
Super Star Member
- Joined
- Jan 14, 2011
- Messages
- 12,387
- Tractor
- Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Researching a disc harrow for a 4,000 pound tractor with HST, 4-WD and 45-horsepower for creating small food plots. Is there a rule of thumb for hp/size of harrow? Red iron clay soil.
Cutting unbroken ground for food plots requires a Disc Harrow with pans at least 20" in diameter, which yields ~~ 50 pounds of pressure ~~ on each pan.
Twenty-two inch pan diameter better. If your rear tires are filled with fluid you will be glad pulling twenty-two inch diameter pans.
Scalloped pans front and rear cut unbroken ground much better than smooth pans.
Nine inch spacing between pans penetrates somewhat better than seven inch spacing between pans.
Nine inch spacing between pans allows 5" to 7" surface rocks to pass between angled pans.
Seven inch spacing between pans penetrates soil less but leaves a somewhat smoother output.
Disc Harrow width should be no wider than your rear tires for food plots, preferably slightly narrower, for maneuverability moving forward and in reverse. You need to pass between trees with both the tractor and implement, with tractor potentially turning a bit. Hanging up a Disc Harrow between trees on a slope can be miserable.
MORE: https://www.tractorbynet.com/forums...ing-three-point-hitch-mounted.html?highlight=
