G6200 HST Hydro Release
   / G6200 HST Hydro Release #1
Speckred17
Waco
Kubota G5200, Sears Professional 27 HP, John Deer 260
Hello all,
I have an issue with my G6200 hst and need to load it on my trailer to get fixed. Is there a release valve somewhere for the hydro? I can't find anything anywhere. I do not want to winch it on my trailer without releasing that.
Thank you for your help.
   / G6200 HST Hydro Release #2
Hello all,
The operator's manual (Section 5) for both geared & HST states: IMPORTANT: DO NOT TOW THIS MACHINE. Damage to transmission may result.
Not sure how to read that - does it mean never push the tractor, even a few feet, or don't tow it behind your pickup on the interstate like a trailer? I never could find any kind of release like the little pull/push one that our Craftsman had. Not wanting to ever have to fix that Eaton HST, I have tried to observe the operator manual's advice.
Over the years I have rolled it forward (engine & parking brake off) a few feet with no noticeable problems.
I once had to move it from out of our field to our shop, where I could work on it. I did that by pinning the front axle pivot with wood wedges, securing the steering wheel and towing the tractor, backwards, by lifting the rear wheels off the ground with a boom pole on a larger tractor. Not sure if that was really necessary, but it worked.
For winching it onto a trailer - consider bringing a suitable dolly & floor jack. Get the tractor in position behind the trailer, lift the rear end with the jack & put the dolly under the rear tires or rear frame. With the tires off the ground, you should be able to winch away.
Thanks for the reply. That is what I am seeing. I have looked all over for a release. On both my craftsman's and my John Deere, there is a release so it rolls freely. Was hoping I could find that with this one.
   / G6200 HST Hydro Release #4
2015 Volkswagen Jetta Sedan (A50324)
2015 Volkswagen...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
Vermeer 840 Discbine (A50774)
Vermeer 840...
Grasshopper 618 Zero Turn Mower (A50514)
Grasshopper 618...
Adams 5 ton Fertilizer Buggy / Wagon (A52748)
Adams 5 ton...
