G1900 starter pics?
/ G1900 starter pics? #1
adventure bob
Platinum Member
Here
JD 345/ Kubota Side by/ kubota ??
I made the mistake of taking the starter solenoid out without taking a pic. Solenoids have no markings on them. Need to reconnect.
Could someone either take a pic or post the tos/froms for the solenoid? I have the manual but its woefully vague about the connections.
Thanks
/ G1900 starter pics? #2
I have a G1900 and will be happy to send you pics, but I'm out of town until Thursday. If nobody else chimes in before then I'll post as soon as possible. Good luck. Jeff
Jk, Ill take it. I have recd no other inputs. Need good shot of the pos wire coming in (which lug. short/long it hooks to specifically) and orientation (long lug towards or away from starter motor). Also which lug the tractor side harness hooks to. Should be able to get in one or 2 pics.
Thanks tons.
AB
/ G1900 starter pics? #4
Hi adventure bob. Here is a pic of the starter on my G1900. I believe this should help with the wiring/orientation questions. If you need other views or information let me know. The "other" wire you see connected to the hot terminal is an aftermarket temp gauge; I ran to the starter to get power.
Jeff
Looks like the longer terminal is toward the actual starter motor? It also looks like the tractor side hot comes off the same terminal the battery hot is on? Cant quite tell cause the red boot is in the way.
Truly appreciate the post of the pic. Lifsaver. Gotta get this running and get the blower on it before it snows.
/ G1900 starter pics? #6
I believe the only hot wire connected to the big terminal is from the battery. The yellow wire is the one going to my aftermarket temp gauge. The other wire connected to the tab is from the ignition switch.
JK, thanks for hooking a brother up. Tractor is back in action.
/ G1900 starter pics? #8
No problem. Glad to finally contribute as opposed to just learning from everyone else!
Supposed to be beautiful here in KY for the next couple of days. Probably mow one last time before putting the G1900 up for winter.
2018 Rotary SM18N001 18,000lb. Hydraulic 4-Post Auto Lift (A66736)
2018 Rotary...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A68842)
TWO PALLETS OF HYD...
porta potty (A67714)
2014 CTS BELLY DUMP (A67714)
2014 CTS BELLY...
2016 Ford Escape SUV (A66738)
2016 Ford Escape...
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
