Buying Advice G174 crankshaft
   / G174 crankshaft #1
VMCopeland
Paris Texas
Iseki G174,Ford 5000,Kubota B5100
Hello I have an Bolens G174 with a spun rod bearing. And need options can any one help? Thanks VMC
   / G174 crankshaft #2
I just sold my Bolens/ISEKI G-174....maybe it's good thing I did....that's gonna' cost....Len may be able to help out....parts are expensive....I feel bad for you....Ampa
   / G174 crankshaft
I just bought it last week and hope to repair it. I'm trying to find out if this engine was used in other brands or applications. Thank You
   / G174 crankshaft #4
Unless the crank is really destroyed a good well equipped engine repair shop can "spray" the destroyed journal and then turn it down to match the other journals. This would probably be much cheaper than buying a replacement crankshaft. Many times the bearings are a standard size inside diameter and they can find a replacement meant for another application and with minimal modifying you can make it work.
   / G174 crankshaft
Thank You for the info. I completed the tare down yesterday and will give that a try I will post the outcome. VMC
   / G174 crankshaft #6
You can get undersized bearings. turn the crank to the largest size you can get by with. If your crank is too bad, i should have one.
   / G174 crankshaft #7
I just pick up a tx1500f very very very cheap but it has a broken crank. Is there any hope ?
   / G174 crankshaft #8
I can supply you with a crank or an engine.
2017 Ford Fiesta Passenger Car (A51694)
2017 Ford Fiesta...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT6DH646717 (A51572)
2013 Dodge Charger...
BUYERS PREMIUM & PAYMENT TERMS (A52577)
BUYERS PREMIUM &...
