Sickle Bar G&S / Superior Sickle Bar Rivet Installation
   / G&S / Superior Sickle Bar Rivet Installation #1
BuckeyeFarmer1994
Southern Ohio
1984 John Deere 2750, 1976 JD 2240, 1951 Ford 8N, 1955 Ford 650
I am having trouble getting rivets to hold after replacing a couple of broken rock guards. I have tried rounding them over with a ball peen hammer, and heating them with the acetylene torch prior to rounding, but neither method has worked. The rivets have sheared off again within a couple of hours of mowing. Any suggestions? Is something out of adjustment with the cutter bar that may be causing this problem? Any help would be greatly appreciated!!
   / G&S / Superior Sickle Bar Rivet Installation #2
To properly set a rivet you are not just interested in rounding the head... Your actually expanding the diameter so it captures the hole of both pieces and fills completely.
Also be sure that both pieces are tightly clamped together BEFORE setting the rivets. KennyV
   / G&S / Superior Sickle Bar Rivet Installation #3
Thanks for the information. Based on these instructions, I do not think I have got the rivets tight enough.
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
Informational Lot - Shipping (A55314)
Informational Lot...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
2003 PETERBILT 330 DUMP TRUCK (A55745)
2003 PETERBILT 330...
