FX24D Not running
/ FX24D Not running
YUP guilty.. life got CRAZY.. but im back baby.. no real updates yet so hopefully not jinxing this. Reviewing this thread to get back on track.. ive forgotten a bunch of details but thankfully ive kept good notes here.
/ FX24D Not running #92
That's what a forum thread does best. It's like a build blog or a diary of sorts to revert back to.
Hope the machine is getting closer to being put back together. :)
/ FX24D Not running
Took the engine to a different machine shop that works on crankshafts. He measured the crankshaft journals. He said the damaged one could not be turned since it was beyond the the specs for that. He said to replace it or have it welded and turned to size 10? (i believe he said all of the journals (main and connecting rod) would be turned to size 10. He also stated that the connecting rod was damaged beyond use. So new one of those. He suggested to get all 3 pistons upsized (20) and to bore the block to accommodate.
Unfortunately he was not able to find parts from his distributor so he couldn't quote me on that but I showed him some of the rebuild kits ive seen on ebay and the parts from Hoye.
He quoted me 200 to correct the existing crankshaft, plus another 200 to bore the engine.
i would have to purchase the parts, i see hoye has this piston and oversized at 25 or 50mm. Is the 25 the 10 oversized piston (25mm = .098 inches?)
Can i even get main and rod bearings for the new size?
Or should i just but a new crankshaft. Seems like i can find new ones for 300-500$ i would need to confirm that they fit.
He also quoted me 250$ to rebuild the head and 150$ to clean and resurface.
/ FX24D Not running #94
I'm not sure of your engine really. If it has sleeves for the pistons, then why oversize by boring???
/ FX24D Not running
I asked the guy the same question and he says for him it's easier to bore for a larger piston then re sleeve and then bore it out again. He said you need to bore a little on the new sleeves too. Not sure if that's true or not
/ FX24D Not running #96
the F or FX24D is not a normally sleeved engine.
/ FX24D Not running #97
I'm showing Fredricks F24 EP -2224 84mm. and EP2224A 0.25mm over Ep-2224B 0.50mm over
2012 Chevrolet Van (A55973)
2012 Chevrolet Van...
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
(INOP) 1996 FORD F150 SINGLE CAB TRUCK (A59823)
(INOP) 1996 FORD...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
