FX22D engine problem
/ FX22D engine problem #1
professor
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
I have a friend that has a F22D and this weekend while he was doing some loader work the engine began to sputter and stopped. He started it but it sputtered for several seconds and then straightened out but a few minutes it did it again. I checked the following for him:
Air cleaner clean
Water doesn't appear to be in fuel (the tractor is shedded)
The tractor will start on full throttle sputter several seconds smooth out to about 2400rpm then sputters again and stops
No white or black smoke observed
Any suggestions will be appreciated.
/ FX22D engine problem #2
dirty fuel filter, dirty fuel tank ?:confused:
Empty the tank, and blow out the lines, replace the fuel filter, fill w/fuel, bleed the fuel system, and see if that cures it.
/ FX22D engine problem #3
Definately sounds like fuel problem. Maybe "air" getting in line... Might check the lines between the injectors!!!!
/ FX22D engine problem #4
I agree with the others. Sounds like it is starving for fuel.
My old TO 30 Ferguson was doing the same thing and it was the fuel filter.
2025 GIYI GY-PG72C 72in Dual Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A61572)
2025 GIYI GY-PG72C...
2016 Ford F-250 4x4 Pickup Truck (A61573)
2016 Ford F-250...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
(2) UNUSED 17.5L-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
KUBOTA B3300SU TRACTOR (A64280)
KUBOTA B3300SU...
2015 Ford E-350 Shuttle Bus (A61573)
2015 Ford E-350...
