fuse problem
/ fuse problem #1
yardman66
bobcat 341
I have a Bobcat 341 excavator I need to know where the 2 speed solenoid is located Ive tried the dealer but they dont call me back I keep blowing the fuse so I want to test the solenoid Thanks
/ fuse problem #2
also, look for corrosion on the fuse holder, which makes a bad contact, and heats up the fuse, making it blow under normal current!..
/ fuse problem
thanks I will check that also
/ fuse problem #4
The 2 speed coil is on the manifold block, a rectangular aluminum block just below the control valve with an accumulator at one end. Location of the solenoid changes with serial numbers, but most blocks had 4 solenoid coils 3 of the coils were PWM (variable opening) and 1 for speed is simple on/off. Look for the one that is different. Probably second one from accumulator end.
/ fuse problem
Thank you for getting back to me I really appreciate the information
2022 FORD F-150 (A63569)
2022 FORD F-150...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
Bandit 250XP Wood Chipper (A63118)
Bandit 250XP Wood...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2023 Kubota Z252KH-54 Zero Turn Mower (A63118)
2023 Kubota...
Gradall no crank no start (A61568)
Gradall no crank...
