fuse problem
   / fuse problem #1
yardman66
bobcat 341
I have a Bobcat 341 excavator I need to know where the 2 speed solenoid is located Ive tried the dealer but they dont call me back I keep blowing the fuse so I want to test the solenoid Thanks
   / fuse problem #2
also, look for corrosion on the fuse holder, which makes a bad contact, and heats up the fuse, making it blow under normal current!..
   / fuse problem
thanks I will check that also
   / fuse problem #4
The 2 speed coil is on the manifold block, a rectangular aluminum block just below the control valve with an accumulator at one end. Location of the solenoid changes with serial numbers, but most blocks had 4 solenoid coils 3 of the coils were PWM (variable opening) and 1 for speed is simple on/off. Look for the one that is different. Probably second one from accumulator end.
   / fuse problem
Thank you for getting back to me I really appreciate the information
GS-3246 MAN LIFT (A52472)
GS-3246 MAN LIFT...
John Deere 9420R Tractor (A53342)
John Deere 9420R...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2020 COLOMBO TM LOT NUMBER 218 (A53084)
2020 COLOMBO TM...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
