Fuse block
/ Fuse block #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
Having added LED lights to several Kubotas, I usually use the factory's wiring for one set of rear work lights, and run a hot wire to a relay for switched power for front lighting. I just ran across this nifty little fuse block, and thought I'd share. A fused 10 gage hot wire from the battery, a relay powered off the ignition switch, and you have 6 fused terminals for all your accessories.
Amazon.com: OLS PSZACCEPS051H 6-Way LED Illuminated Blade Fuse Box with Cover: Automotive
/ Fuse block #2
Sweet! Thanks for posting that. I have a lighting project that needs to happen before snow clearing time and that should make it much more flexible for adding more lights in different places on the tractor.
/ Fuse block #3
My thoughts exactly!
/ Fuse block #4
Thanks Varmint, which relay do you use?
/ Fuse block
Just saw your question, mddorange. I bought this: Absolute USA RLS125-5 SPDT 30/40A 12 VCD Automotive Relay - 5 Pack from Amazon, $6.45 delivered. I figured if one crapped out, I would just toss it and install another. Never a problem with them, but I don't use lights every time out- in fact, not often at all in the summer.
/ Fuse block #6
Thanks for the reply. I am thinking of doing something similar. Do you have any pictures?
/ Fuse block
md, if you mean photos of the relay installed, nope. I wound up mounting it just above the fuse box on the left side of the tractor's console(?), where it is protected from weather but still accessible, mostly so I could simply wire it without tearing anything apart. I ran a 10 gauge red wire from the battery hot terminal (fused, of course) to it for a solid power source, and the light switching wire is powered from the fuse block, which is switched from the key. I figure if I want, I can add even more forward LED lighting. The rear lights, 54 watts total, seem to be more than enough.
/ Fuse block #8
Thanks, that was what I was looking for.
/ Fuse block #9
These are great. For my Frank-N-Ford project, I ran my power from the key switched solenoid so nothing runs down the battery unless the key switch is on. Much cleaner, simpler and more effective than the old bake-lite wire blocks.
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A64557)
2017 Forest River...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
TROY-BILT GENERATOR (A64553)
TROY-BILT...
2004 IC Corporation 3000IC School Bus (A64194)
2004 IC...
2021 TORO MRTX2500 68138HD STAND ON CONCRETE BUGGY (A63276)
2021 TORO MRTX2500...
2012 Peterbilt 337 S/A 18.5ft Cab and Chassis Truck (A64194)
2012 Peterbilt 337...
