furrows after tilling
/ furrows after tilling #1
eholm
Very much a newbie (just putting an order in for a 2230 this week). I will be mowing a couple of acres and keeping a couple hundred feet of dirt road and driveway in condition. Question I have is what attachment would be good for "hilling" up soil after tilling. I live in a flat area where some crops need to be hilled up. Any suggestions? /forums/images/graemlins/crazy.gif
/ furrows after tilling #2
My tiller, as most do I assume, has an adjustable rear "gate" to smooth the ground after a tiller pass. You could probably fab something to bolt to this gate to create some furrows. Should be easy and fairly inexpensive..
Ron
/ furrows after tilling #3
Ah, yes...
What you are looking for is called a "furrow diker."
If you do a Google search on this term, or related terms such as "basin tillage," you should find what you are looking for.
My experience with the furrow diker comes from Idaho, where we used flood irrigation in our fields. Typically, a field is divided into multiple "lands" with low dikes (maybe eight to 12 inches high). The dikes allow you to flood one land at a time from an irrigation ditch. Without the dikes, it would be very difficult to get the water to flow by gravity just where you wanted it to go.
For what you want to do you could probably fabricate a light-duty version of a furrow diker to fit on your 3ph.
/ furrows after tilling #4
I would suggest you get a disk bedder. It looks a lot like regular disks, but is used after preparing the seed bed and will generally bed rows up to 16" high. Here's an example web site:
Disk Bedder. My cousing swears by his. He uses Two gang disks to prepare and then a similar-to-the-example disk bedder. They make easy work of bedding. John
/ furrows after tilling #5
I got all excited about the Disk Bedders, but after reviewing the WEB page, isn't this application for grown up tractors? Seems like the 22" raised beds need 90 hp or more? That is serious horse power.
Maybe I read the information incorrectly? I hope I did because creating raised beds off the back of a CUT would be great.
/ furrows after tilling #6
I looked for a while for some small versions of these things. You can find one in the AgriSupply catalogue by the name of Keulavator ...or somthing like that.
I almost ordered that one, but I found a more versitile tool locally. The one I have has a 5 ft toolbar to which can be mounted cultivators (up to 4), middlebusters, smallish moldboard, or sets of outrigging disks (14" notched).
It works really well, but good luck in finding one...the one I bought I got used, and it was made by Ag-Meier, Inc. in Brenham, TX.
It's not that complex of an impliment, and I would bet one could be made with very little welding skill and a little part shopping from andy TSC or AgriSupply.
Sam
/ furrows after tilling #7
</font><font color="blue" class="small">( Seems like the 22" raised beds need 90 hp or more? )</font> My cousin uses a NH TC30 to pull his bedders. There are many manuf. who make bedders for CUTs. I'll call and ask him what brand his are. Let you know. Do you really need 22" beds? I wouldn't think so. John
/ furrows after tilling #8
As I posted earlier, I called my cousin, but he's not at home and can't remember the name of his bedders, but Leinback makes some small, 2 disk bedders and I took some pictures of them at my dealer's today. What's showing are two different colors. The disks fold out perpendicular to where they're show in the pics, then pics of a single disk and it's shaft from each side. John
Leinbach bedder
/ furrows after tilling #12
The disks are cupped, which is a little hard to tell in the pics, so that they throw the dirt between them into a hill. I hope this helps, John
/ furrows after tilling #13
These look a bit like the thing ASC sells. I forget the name...something like Agrigator or somethin glike that. It can be had w/ hilling disk or points.
/ furrows after tilling #14
Below is stuff I copied from another thread on this earlier. The Twin Oaks folks just till and then shovel pathways for wheelbarrows/walking with a shovel. My organic gardening teacher has a furrow plow with adjustable sides that he puts onto his BCS tractor after tilling to make pathways.
Below is from the previous thread:
Row hiller
In Agra supply catalog.
Called Keulavator Row Shaper & Cultivator Frame for $139.95
for 3 pt hitch.
The 3pt keulavator from Agri-Supply at $139 is misleading. The complete price is just over $400 which gives you 2 hillers, 2 sweeps, and 2 shanks plus mounting hardware. Just the frame by itself is $139.
I have never done this and don't even have a garden but was wondering if you couldn't make the beds with a rear blade. With the soil well tilled and a rear blade at max angle wouldn't the windrows form beds. I have cut ditches with a blade and it works well to a point. Might even pay to buy a short 4' blade just for that purpose.
i use a 5' blade to make raised beds.started out with a row hipper set as far apart as possible & ended up with 4 rows.then i put the 5' blade on & pushed the 2 outside rows into the 2 inside.makes really wide ,deep beds.
Ralph
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
2015 Nissan Altima Sedan (A64557)
2015 Nissan Altima...
INOP/NON - RUNNING 1997 Procraft Fish/Ski Boat (A65579)
INOP/NON - RUNNING...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
