Fully Loaded
/ Fully Loaded #1
tsteahr
CT shoreline
Massey Ferguson GC2410tlb w/ R1 and Rimguard
Took a drive to the dealer yesterday. Brought my front tires with me to get loaded with Rimguard. I've had this on my mind since I got my GC2410 TLB. When I go up a fairly steep slope, the front can get light enough so I can't turn the tractor. Front tires are coming of the ground. I suspect the 50 lbs of thumb welded on the bh contributes to this.
Now I know the front tires on a scut are tiny. But I figured every little bit helps, right? Got em filled, probably a little over 2 gallons in each tire. I'm guessing each tire was about 25lbs heavier after the fill.
Fired up the tractor today, headed for the same slope and sure enough, I now had just that little bit extra weight to keep the front tires on the ground so I could steer. :cool2:
So I can say loading the fronts of a scut won't transform the machine, but in certain situations it is noticeable. And the best part was the bill at the dealer came to $10 :thumbsup:
/ Fully Loaded #2
Glad it worked out for you. Results for 10 bucks is hard to come by now days. :thumbsup:
/ Fully Loaded #3
$10 heck of deal. :)
Maybe dirt in bucket might help w/more traction..off set BH.
/ Fully Loaded #4
Do you have l/r split brakes? You can very effectively augment steering with those.
larry
/ Fully Loaded
larry
I wish I did. These little SCUTs don't have split breaks.
New/Unused 3 Point Receiver Hitch Attachment (A65583)
New/Unused 3 Point...
(2) Truck Rims and Tires (A65640)
(2) Truck Rims and...
Heavy-Duty Round Livestock Bale Feeder w/ Hay Saver (A66408)
Heavy-Duty Round...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
