Full throttle or 80 to 90%?
/ Full throttle or 80 to 90%? #1
johneic
Paducah (West) Kentucky
JD 3038e, Bolens-Iseki G174 2 Cylinder (early), Kubota B7200E 2WD belly mower
Since our mechanical injection pumps have a governor, am I wise to throttle down from full throttle or not?
/ Full throttle or 80 to 90%? #2
What are you doing?
Usually just finish or brush mowing, both are four footers.
I just have it in my head not to run any engine at full throttle.
So lets assume our engines are governed to 90% of maximum power and I throttle back from there, then I am only running at 75% ish power? If this is true there would be no reason to throttle back?
/ Full throttle or 80 to 90%? #4
as long as you are not "lugging" an engine for the task at hand, ( or going too slow for proper PTO speeds ) you are good to go .....
/ Full throttle or 80 to 90%? #5
Run it at PTO rated speed. That is where you will get PTO rated power. Any faster "could" damage the mowers. Slower is just costing you power and performance.
