fuel valve posiyion
   / fuel valve posiyion #1
RayGuidry
Leesville, Louisiana
branson 3510
New guy from Louisiana. Ray Guidry age 50. i have a branson 3510 and need help with the fuel petcock position. what else do you want to know about me.
   / fuel valve posiyion #4
Welcome to TBN, Ray. As far as your petcock, I don't know Branson. An owners' manual should answer your question. I do know that most water valves are turned so they align with flow to turn on or go across the direction of flow to turn off. My old Mitsubishi tractor was the opposite. The handle was turned across the flow to turn it on and in line with the flow to turn it off. You can try cracking a line after the valve to see how it works.
   / fuel valve posiyion #5
Welcome to the forum!
:tractor: I'm going to move this thread over to our Branson section.
   / fuel valve posiyion #6
Welcome to the site. Enjoy your Branson....a quality product by far.
You can see that I don't have your tractor. Valves of which I am familiar, are either threaded or quarter turn devices. Threaded you turn CCW to let fuel flow and obviously the reverse to close. The quarter turn usually have the lever parallel to the fuel line for flow and perpendicular for closed.
   / fuel valve posiyion #7
Ray, How old is that tractor? I have a Century 2535 which is the same thing as the Branson 3510. I had a problem where the pawls on the valve control lever did not engage fully with the nylon valve assembly. When I turned the valve off it would bot turn back on and I had to remove the valve control lever and turn the actual valve itself with a pair of needle nose pliers. Mine stays in the on position all the time now. If I need to change the filter I just put a cup under the filter bowl to catch any fuel that leaks out. W. Jones
UNUSED AGT KRW23 WHEEL LOADER (A51247)
UNUSED AGT KRW23...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
(1) FRIGIDAIRE REFRIGERATOR (A51248)
(1) FRIGIDAIRE...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53472)
2016 KBH...
