Fuel to injector pump, but won't start. Solenoid and injector questions
   / Fuel to injector pump, but won't start. Solenoid and injector questions #31
I'm glad you got it going and I'm glad it was a simple fix.
Don't forget to put a Racor 120AT on it.
Oh, I'm planning on it!
I also want to put a better water filter on my pump setup. I currently have a Baldwin BF1212, which is probably just fine for clean fuel, but I'd really like something with a clear bowl so I can monitor what's in there.
Any suggestions? I'd like to keep the same base, which is a 1-14 base.
   / Fuel to injector pump, but won't start. Solenoid and injector questions #33
Glad she's running.. it could have gotten pricey.
Do a search for Racor filters.. they have a small one w/ hand primers and heaters & water sensors..
Ford, Perkins, Massey Ferg. have some w/ plastic/glass bowls..
Based on input from several threads, including this one, I'm going to use the Racor 120 on the tractor. I would like something bigger with a bowl for my fueling system.
   / Fuel to injector pump, but won't start. Solenoid and injector questions #35
A quick follow up. Yesterday it removed a cedar stump and filled in the hole. Back to work!
   / Fuel to injector pump, but won't start. Solenoid and injector questions #37
Yes, I got off easy.
I've ordered a Racor 120 from racordiscounts.com It's half the price of Amazon!
I'll post some pictures of the installation when I get it done.
I also ordered a 3 pack of the Baldwin 1212 filter for my pump, but I'd still like to find a compatible filter with a clear bowl for the pump.
   / Fuel to injector pump, but won't start. Solenoid and injector questions #39
Thanks for all the info!
   / Fuel to injector pump, but won't start. Solenoid and injector questions #40
I have a video on the fuel filter upgrade.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
2018 PETERBILT 567 (A50854)
2018 PETERBILT 567...
2015 LINK-BELT 235X3 SPIN ACE EXCAVATOR (A50854)
2015 LINK-BELT...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
