Fuel to injector pump, but won't start. Solenoid and injector questions
   / Fuel to injector pump, but won't start. Solenoid and injector questions #31
I'm glad you got it going and I'm glad it was a simple fix.
Don't forget to put a Racor 120AT on it.
Oh, I'm planning on it!
I also want to put a better water filter on my pump setup. I currently have a Baldwin BF1212, which is probably just fine for clean fuel, but I'd really like something with a clear bowl so I can monitor what's in there.
Any suggestions? I'd like to keep the same base, which is a 1-14 base.
   / Fuel to injector pump, but won't start. Solenoid and injector questions #33
Glad she's running.. it could have gotten pricey.
Do a search for Racor filters.. they have a small one w/ hand primers and heaters & water sensors..
Ford, Perkins, Massey Ferg. have some w/ plastic/glass bowls..
Based on input from several threads, including this one, I'm going to use the Racor 120 on the tractor. I would like something bigger with a bowl for my fueling system.
   / Fuel to injector pump, but won't start. Solenoid and injector questions #35
A quick follow up. Yesterday it removed a cedar stump and filled in the hole. Back to work!
   / Fuel to injector pump, but won't start. Solenoid and injector questions #37
Yes, I got off easy.
I've ordered a Racor 120 from racordiscounts.com It's half the price of Amazon!
I'll post some pictures of the installation when I get it done.
I also ordered a 3 pack of the Baldwin 1212 filter for my pump, but I'd still like to find a compatible filter with a clear bowl for the pump.
   / Fuel to injector pump, but won't start. Solenoid and injector questions #39
Thanks for all the info!
   / Fuel to injector pump, but won't start. Solenoid and injector questions #40
I have a video on the fuel filter upgrade.
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A52128)
2018 Ram 3500...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2019 KENWORTH T680...
Aer Way Tillage Tool (A50514)
Aer Way Tillage...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
2016 Dodge Caravan (A50324)
2016 Dodge Caravan...
CATERPILLAR 305CR EXCAVATOR (A51242)
CATERPILLAR 305CR...
