Fuel Tank for flatbed 350
/ Fuel Tank for flatbed 350 #1
Michael Brown
Whitesburg, GA
Ford 4000 Bushhog FEL : John Deere 955
Hello all!! I am looking for a source for gas fuel tank on a newly acquired 95 F350. It has a factory switch for two tanks. The larger one is in front of axle and smaller behind it. The one is back is a poly tank and it is leaking. Both tanks are mounted in center of the 11 ft long bed. So far no luck with Ford. Any one have any ideas? Thanks to everyone to that uses this forum, I do find lot of things on here very informative.
Thanks.............that is not what is in there but it might work.....I will check it out.
/ Fuel Tank for flatbed 350 #4
So this must be a factory cab and chassis if rear tank is plastic. Pickup bed model would have had two 19 gallon steel tanks. It's tough to find that rear tank used and nobody makes it new. Two choices...try to repair leak or convert to spectra steel tank with new pump and straps?
/ Fuel Tank for flatbed 350 #5
Didn't the Ford Excursion have a 50 gallon tank behind the axle? Should fit the F-350.
Good luck.
More info coming soon. (A64557)
More info coming...
CENTRAL PNEUMATUC 9 GALLON GAS AIR COMPRESSOR (A67714)
CENTRAL PNEUMATUC...
WARREN POWER SYSTEM LIGHT PLANT (INOPERABLE) (A68842)
WARREN POWER...
2016 FORD F450 CREW CAB SERVICE TRUCK (A69167)
2016 FORD F450...
1999 INTERNATIONAL 4700 4X2 FLATBED DOVETAIL TRUCK (A65057)
1999 INTERNATIONAL...
2019 Toyota Camry Hybrid Sedan (A66738)
2019 Toyota Camry...
