Oil & Fuel fuel system issues
/ fuel system issues #1
Huckster
Bronze Member
My 2535 keeps cutting out on me and I believe its a fuel system issue. While I was changing the fuel filter I turned the fuel lever back to the on position and nothing came out. I believe this would mean that maybe my tank has a blockage. Any suggestions on how to trouble shoot this without having to take the whole system apart?
/ fuel system issues #2
Huckster, I had a similar problem a couple of years ago. I actually had to remove the shutoff lever on the fuel filter assembly and turn the nylon valve with a large screwdriver to get it to where the fuel would flow It was open just enough to allow the tractor to run at idle but it would not get enough fuel to run under a load or high rpms. WHat is happening is that the lugs on the lever are too short to fully engage the slots in the nylon valve assy. They disengage when you close the valve and will not reengage when you try to open it. Since you do not have to mess with the fuel filter very often it is not a big deal. Check that first before you mess with the rest of your system. A quick test is to unhook the fuel line on the inlet side of the fuel filter assembly and turn the key on. if fuel flows the problem is your filter valve. Don't forget to bleed the air out when you put it back together.
Good luck. I spent a couple of very frustrating hours before I isolated the problem. Willie Jones
It was the fuel pump, but thanks for the help.
2011 FORD F-150 (INOPERABLE) (A67714)
2011 FORD F-150...
PORTA POTTY (A68842)
2016 BIGHORN 5th WHEEL (A67714)
2016 BIGHORN 5th...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2012 TEXAS PRIDE T/A GOOSENECK TRAILER (A67714)
2012 TEXAS PRIDE...
PAIR OF PIPE RACKS (A68842)
PAIR OF PIPE RACKS...
