Fuel station - nozzle dusty
/ Fuel station - nozzle dusty #1
S854
Platinum Member
Helena, MT
‘67 MF 135 Deluxe / ‘22 Kioti CK2610 HST/Bad Boy ZT Elite 54”
I recently purchased a CK2610 HST… it was actually delivered yesterday… fun stuff… it has joined our growing tractor family (‘67 MF 135 Deluxe, ‘92 Craftsman GT 5000 and ‘65 Case 130)…
my question, however, is in regards to an older style 33gallon Fill-Rite fuel tank/pump I have on our property… (read: “all metal -- nozzle, pump, shut-off lever, nozzle holder”)
we have considerable wind here which stirs up the fine dust in the driveway… that dust is attracted to the diesel nozzle… I’m able to wipe the outside of the nozzle, but I’m concerned about the dust which settles on the inside of the spout…
obviously, there is a fuel filter in the tractor circuit and also one after the Fill-Rite pump (which does no good in regards to the dust in the nozzle)… the amount of dust inside the spout is miniscule… but it’s still there…
prevously I pumped the first shot of fuel back into the 33 gallon tank, then filled my tractor’s tank… not really keen on continuing this practice…
looking for ideas on how to keep this nozzle “dust free”…
I should mention we have young grandchildren around who are very good at being young grandchildren… the nozzle remains locked in its holder when not in use so I can’t simply “put a bag” over it… that would be too easy…
thanks in advance for any and all suggestions
P.S. here’s a pic of my new toy
/ Fuel station - nozzle dusty #2
Find something slightly smaller than the inside diameter of the nozzle and fashion a plug. I fashion a plug for my PTO connector out of a paper towel but you can get more elegant. For example if a piece of half inch PVC would barely fit into the nozzle a cap glued onto the end would keep the dust out and prevent the pipe from going in too far. Think outside the box.
/ Fuel station - nozzle dusty #3
I made a holster for my diesel nozzle out of 5" vinyl firehouse. Works well in the back of my truck, easy on - easy off.
I doubt the small amount of dust is an issue, but there is also no reason to unnecessarily introduce any amount of contaminants to your fuel system or tractor.
/ Fuel station - nozzle dusty #4
Just wrap a plastic bag around the nozzle when not in use. That what I do with my funnels; keeps them clean, and the bugs/spiders out too.
/ Fuel station - nozzle dusty #5
Not something I get concerned about especially after having installed a Racor style fuel polishing unit between the tractor tank feed line and the primary fuel filter and the strainer in the fuel filler tube too.
/ Fuel station - nozzle dusty #6
I use a spare hydraulic coupler cover on my filler nozzle. Fits snug on the 3/4" nozzle.
/ Fuel station - nozzle dusty #7
In addition to dust, I've also had insects crawl inside the nozzle as well. Dust & debris also collects on the outside. As you say, wiping solves that issue if you have a rag handy and remember to do it.
I use these vinyl caps on the nozzle end. They protect both the inside and outside:
The 3/4" size is a good snug fit on my nozzles but measure first before ordering.
/ Fuel station - nozzle dusty #8
I turned a piece of aluminum and cut groove for o-ring to fit in nozzle. Keeps things out and diesel from dipping on truck from transfer tank. I've got a 100 gal mounted in truck!
Thanks for the ideas…
As I said… young kids in the mix and a tight fit in the locking Metal holster…
I’ll measure the I.D. and O.D. of the nozzle next time Out, then fashion/order a plug/cover depending on available room…
I’ve had this fueling system for about six months and have never looked “up” inside the open end of the holster once the nozzle was inserted… go figure…
/ Fuel station - nozzle dusty #11
Cant you just throw a rag over the end?
The holster for the nozzle is made of narrow, metal channel… open at the bottom… there are holes in the channel to place a long shackle lock (grandkids)… which limits the amount of space available to place any protective cover over the nozzle…
A large part of the problem is the wind here… it blows our fine dust deep into anything and everything… something which is not secured somehow will eventually get dislodged or blown away…
taking from some of the ideas presented here… I had an Ah-HA moment over the weekend… I need to repair a cut garden hose… I removed an extra 8” from the repaired hose, folded over one end (to keep the dust at bay, and was able to fit it over the open end of the nozzle… it’s a TIGHT fit… both on the nozzle and just enough room between the nozzle and the holster…
It‘s probably not ideal (takes quite a bit of finagling to get it secured) but it’ll work for now… I hope…
/ Fuel station - nozzle dusty #13
Use caution when placing a protector plug inside the nozzle. It's very easy to forget it's there and can wind up in your fuel tank.
Good point… hadn’t really thought about that…
/ Fuel station - nozzle dusty #16
Forgot to mention to tether the plug so that you don't lose it in the tank. Also you won't forget to replace when done fueling.
I like the idea of a stopper on a tether… out of the way when fueling… easy to wipe the nozzle with a rag… “difficult” to forget when done…
Ill find one at the local ACE… along with an eyelet to screw into the large end…
/ Fuel station - nozzle dusty #18
I printed up some covers out of TPU filament for the intake & nozzle on mine, mainly to keep bugs out.
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
43055 (A55851)
43055 (A55851)
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
Morgan 26ft Box Truck Body (A59228)
Morgan 26ft Box...
