Oil & Fuel FUEL SHUT OFF LEAK
/ FUEL SHUT OFF LEAK #1
WACO
Has anyone had to fix a fuel leak at the fuel shut off valve shaft? Before I take it all apart I was wondering what I might need to repair it. This is on my 1510D if it matters.
/ FUEL SHUT OFF LEAK #2
On my 1700, It leaked everywhere, at the shutoff, on the bleed screws, at the bowl... I know it was just orings, but I ended up replacing the whole bowl assemble in desperation one day. I would like to have done it oem.. but was in a bind and just ran down to the store and got a generic diesel one that just fit.
Soundguy
/ FUEL SHUT OFF LEAK #3
WACO,
I have a YM1110D on which the shutoff didn't work. The lever is that cheap "pot metal" junk. It has two little prongs that engage a plastic cone shaped valve assy. It also leaked a little. It is a very simple arrangement. All you have to do is remove the little screw on the top of the fuel bowl assy, and the lever will come out - but be careful, because there is a little spring in there as well. It won't fly apart - but remove the lever slowly so you don't lose the spring. There is a little o-ring around the shaft where it runs inside the fuel bowl assy. You should be able to get a replacement almost anywhere that sells this kind of stuff. The parts manual lists it as a P-10A o-ring.
I scanned part of my parts manual from the YM1510D and attached it here. The o-ring is No. 7 on the list. I think this filter bowl assy was used on all YM series Yanmar tractors. If you can't get the o-ring from anywhere else, you can get it from a Yanmar dealer, since it was used on the U.S. Yanmars like the YM135, and YM155.
Hope this helps.
Greg
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2020 JLG SKYTRACK 12054 TELESCOPIC FORKLIFT (A60429)
2020 JLG SKYTRACK...
UNUSED IRANCH HYD THUMB CLAMP (A60432)
UNUSED IRANCH HYD...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2018 VOLVO EC480EL EXCAVATOR (A60429)
2018 VOLVO EC480EL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
