Fuel pump
/ Fuel pump #1
jeson
Markusminde, Denmark
Ford 4000
Hi,
My Ford 4000 runs fine, but a couple of times in the last weeks it suddenly stops... When I try to start again nothing happens - the motor turns but it dosen't fire. Because there's no smoke at all I think it dosen't get any fuel. So I try to bleed the fule pump and it starts and runs fine again!
I can't find the reason - it is strange because it just happens now and again - mostly it runs fine. Any suggestions?
/ Fuel pump #2
G'day sound like you might have a blocked filter to me and making the pump suck air, check all your fuel lines from the tank to the inj pump for cracks/looseness
Jon
/ Fuel pump
Hmm... Just thinking it's strange it's not consistently... I'll add a new fuel filter and take a look at the lines...
/ Fuel pump #4
G'day you could also check the fuel tap where it fits into the tank the small strainer screen may be blocked
Jon
/ Fuel pump #6
Ran into a problem like that with a yard sweeper and found that it was a simple fix crap in the tank plugging the outlet then swish the gas and the thing would run fine for a bit. So I agree with jon
ROLLINS 8' X 24' GOOSENECK TRAILER (A64276)
ROLLINS 8' X 24'...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
Kubota L2501 (A64126)
KMC 4R36" STRIP-TILL PLOW (A64276)
KMC 4R36"...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
