Oil & Fuel Fuel Pump Timing Help??
/ Fuel Pump Timing Help?? #41
Bruce thats good advice and very true, I had an engine do that once also.
Mark the pump offer is still open to you if you decide to go that route, (better than a tear down)
Ernie
/ Fuel Pump Timing Help?? #42
Hello Mark, I've been watching the progress on the engine for a while now but have not posted since I'm not a Yanmar expert as these other fine folks are, however I have been a mechanic for quite a few years.
I'd like to offer my suggestion if you would have it, its going to make a mess but take the RETURN fuel line off the injection pump start the tractor and see how it runs also ensure you have return fuel coming out of the pump. I've seen equipment act this way when the return fuel line is somehow stopped up it creates head pressure in the inj. pump and some machines wont run that way, dont know if Yanmar is one of them but it may be worth a try before you tear it down.
I cant see an internal engine problem and it run ok part of the time.
Thanks, good suggestion.
On the Yanmar's the fuel feed is near the bottom of the fuel injection pump, then fed through the top (3) injector lines - direct injection to each injector. The excess fuel from each injector is piped through the top and into the thermalstart bottle (on many) and the overflow directly back to the tank. I have pulled the tank cap and screen and watched the return fuel drip quickly into the tank during all RPM ranges....
I pulled the head (minutes ago) and checked the piston deck height and they are flush. I've rocked each piston to check for end play (slap) and they are snug with minimal movement. #2 cylinder has a beige flashing along with #2 exhaust valve, so valve face and seat are suspect. I will fluid test the valves tomorrow and tear down the head. I hope I have found the problem.
Mark
Purdy sure I do!
It is #2 intake valve face and seat...seat has an area where the valve is obviously not mating perfectly. I did a fluid test this morning and it seeps from 30-45 seconds. I never would have guessed that such a slight problem could create such drastically poor performance.
I have done hundreds of cylinder heads in a machine shop(part time while going to school) and thought I knew most everything about valve problem diagnosing....feeling a little dumb right now.
Mark
/ Fuel Pump Timing Help?? #46
</font><font color="blue" class="small">( feeling a little dumb right now.)</font> On the contrary, Mark. You are now at least ONE learning situation SMARTER than you were yesterday. /forums/images/graemlins/grin.gif
/ Fuel Pump Timing Help?? #47
Did the hyd. pump seal blowing cause this problem ? /forums/images/graemlins/confused.gif
Thanks Wayne.
kenmac, At this point I have to assume it was coincidence. There just is no other explanation I can think of.
The problem with the power just happened immediately after the hydraulic pump repair, and that was why I believed them to be related. I think I would have started weeks ago just pulling the head had it not been a question of two problems happening about the same time.
Mark
/ Fuel Pump Timing Help?? #49
let's hope that was the cause! You found the problem fast in my opinion!
Well after valve stem seals, valve and seat grind, head gasket etc. It did nothing to change the running of my tractor. I have the injection pump removed and found a badly broken and distorted timing shim. I mean it is so bad that it measure .014 on one end and .020. on the other. I have made two .011 aluminum shims and installed and reassembled the engine....runs poorly. Removed one of the .011 shims and it runs better...but not good.
It's my understanding, and from what I've read that the shims advance and ****** the crankshaft timing. And this model, 3T75U engine fires correctly around 21° BTDC. So it's become a process of adding or removing shims to attain the best engine performance....or, a real guessing game without the bench equipment.
Anyone ever go this far into injector pump timing??
Thanks,
Mark
/ Fuel Pump Timing Help?? #51
Why don't you remove the last shim and advance the timing further? Seems like it helped with the first.
/ Fuel Pump Timing Help?? #52
Hi Mark,
I've been following along here, real bear of a problem.
On a yanmar, i'm not sure. However, I've been doing a bit of research on this for my cummins. If the pump timing is too far advanced (from what was originally intended), the engine will not run right at idle. However at WOT (wide open throttle) full rpm, it might run fine. Lower rpms, stumble.
Most folks I've spoke to about pump timing won't do it without the proper tools. However, with that said, if you don't have the tools, maybe a two stage test (idle rpm and WOT) will tell you if it is running acceptably? I don't know, just kinda thinking a loud... Good luck, let us know what happens... !
btw, is this on a 1600 series tractor?
Bruce,
I don't have any shim stock 4"X4" that's thin enough...I do have some on order and will be dropping the thickness from .011 to .008" depending of the thickness of the assortment.
arthr31,
The book (injection pump section) dictates idle to fully open throttle ranges to test injector pump timing. 1mm (or .004") changes crankshaft timing by 1°. So far the changes resulted in no idle, some mid range and no WOT. OR, some idle and WOT but no mid range. It's been trial and error process, but I think I'm on the right course.
It's a 3 cylinder (YM1610D)
Mark
/ Fuel Pump Timing Help?? #54
Just use no shims and see how it runs. It won't hurt anything in the short time it runs in the shop. Then you will(might) know if you're on the right track. /forums/images/graemlins/confused.gif
Even though the shims are at the base of the pump...there has to be some deflection by spacing between the pump rollers and the cam lobes. We're talking thin material here....the thickness of a beer can is .005.
Plus I'm too chicken to put both machined surfaces together without shims..when the manual insists using the correct number and thickness will make the engine timing correct.
/ Fuel Pump Timing Help?? #56
I've done it dozens of times with no problems , but I understand your concern.
/ Fuel Pump Timing Help?? #57
Mark, if you need shims give me a shout, I think I have some in stock
Ernie
/ Fuel Pump Timing Help?? #58
Mark, a couple of things come to mind. Have you assured yourself that the pump and injectors are working properly? Maybe if you beg really hard you can find someone with a parts 1610 tractor that can tell you what it is shimmed at, or possibly even loan you a known good pump to try. T'would be a shame to try and correctly shim up a bad pump.
/ Fuel Pump Timing Help?? #59
I am guessing u will want about .016 to .018 to achieve correct timing. What gauge are the shims u ordered?
Norm, LOL...I'm not quite sure of anything. I see that the machined surface where the pump mounts on the timing cover can vary a few thousandths (from cover to cover)...I also see that the pump itself is very close tolerances internally, but the machined flats at the base of the pump also vary a few thousandths (from pump to pump).
I have the same pump and engine in another tractor (1601) that operates normally...tractor runs fine, good power and no smoke. I gave serious consideration to removing it and putting it in the 1610 but...same problem exists, I'll have to remove or add shims for it to be timed with the crankshaft, pump rollers and cam lobes to this particular application. As a last resort, and if I cant properly time the 1610 with the new shims, I WILL swap pumps and start from scratch with the 1601 injector pump.
I have removed and re-attached all the injectors with this existing pump. All spray evenly according to the book. I have attached a bungee cord to the decompression handle, locked the clutch pedal down, and spun up the engine and watched all three injectors spray into a large coffee can. The pattern is even and alternating correctly...but the timing is too far advanced (or retarded).
Great, Not sure on the set coming...have been at .022", .016" and .011"...shooting for .009" and hoping to be in the ball park.
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
2011 Chevrolet Silverado 1500 Work Truck (A62613)
2011 Chevrolet...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
Frontier RC2060 5ft Rotary Cutter (A65640)
Frontier RC2060...
Land Pride RB3584 3Pt Blade (A66408)
Land Pride RB3584...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
