fuel pump leak
   / fuel pump leak #1
zetor Rick
Zetor 5245
hi, i have a zetor 5245 that has a leaky fuel pump. once i took it apart i could see the three "O" rings on each shaft. porblem is i CANNOT find those "O" rings, or any of that size anywhere. any suggestions?
   / fuel pump leak #2
What I would do is take one of the O rings (assuming they are all the same size) with me to an auto parts store or a tractor dealer/shop and see if they have one to match it.
   / fuel pump leak #3
   / fuel pump leak #4
Any time I have odd o-ring needs I go to a place that specializes in seals. Any decent sized city should have several. You need the proper size as well as the proper rubber compound. You don't want the o-rings to dissolve or swell. Where are you located?
Eric
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Cat TH407C Telehandler (A53472)
Cat TH407C...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
