fuel pump and injector prob.
/ fuel pump and injector prob. #1
moblemike
colton,Ca
1973? Massey-Ferguson AD3 152
just got a MF PerkinsAD3 152 with the fuel pump missing and the 3 injectors in a box and 4 nuts off the engine.i hooked up a bat. and engine cranks over ok, what i need help with is finding apump and fuel line and hardware.theres nothin from the tank to filters, also injectors look like they need to be serviced.Should i have the injector pump serviced also?this tractor been sitin for a couple of years uncoverd.dont know the year of the tractor yet but will by monday.
/ fuel pump and injector prob. #3
G'day when you say fuel pump do you mean the prime pump? If so then any ag place that deals in aftermarket parts should be able to help you out there as for the fuel lines from the tank all those fitting should be 1/2" unf so a 1/2" JIC hyd fitting will fit you should be able to get them with a 1/4"barb and just run normal fuel line. As for the injectors get the correct copper washers that go on the bottom of the inj and fit them up, bleed and see how it goes you may find they are ok you may find not but it is not a big job to pull them out again. If you check out the bare co site you will find everything listed even brand new inj for about the same cost of getting them reco'd but I would see if I can get it to run first and check you have no other eng faults. Should be pretty good they are almost bulletproof little engines.
Good luck and let us know how you get on.
Jon
Oh and :welcome: to TBN
thank you very much you have been a great help
