Oil & Fuel Fuel Problem???
   / Fuel Problem??? #11
Could you tell me what size line wrench to get for my Y485 and where I could pick one up? Napa perhaps?
   / Fuel Problem??? #12
</font><font color="blue" class="small">( Could you tell me what size line wrench to get for my Y485 and where I could pick one up? Napa perhaps? )</font>
I use an 18mm on my KAMA, don't remember if the Jinmas used the same size wrench or not. And sure, NAPA should be able to fix you right up
//greg//
   / Fuel Problem??? #13
//greg//
   / Fuel Problem??? #14
I cannot sat if this was a wise practice or or, maybe others more knowledgable will expound.
I have restarted stubborn airlocked diesels with a chain a few times. Apparently at least some will purge the air through the injectors if given a minute or so spinning at running rpm's.
   / Fuel Problem??? #15
Kubota BX25D (A53317)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
KUBOTA M9000 UTILITY SPECIAL TRACTOR (A59823)
KUBOTA M9000...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
