Fuel leaking around manifold
   / Fuel leaking around manifold #1
momark54
Arnold, MO
'63 Ford 4000
Tractor is a 63 4000 gasser. I visit "Ol Blue" once every week or two. Last few times I tried to start her it would turn over but not start and gas would spray/seep out somewhere around the manifold area. It will eventually start and run kind of rough for a bit and then seems to run fine after that. There's no visible gas leak before starting and oil doesn't seem to have gas in it. On a possible related note(or not) after about 45 minutes it starts running rough, especially under load. Haven't tried troubleshooting that issue yet. On that subject(troubleshooting) I know there's been a lot of good info on here, much of it in bits and pieces. Does anyone know of a link to a good comprehensive step by step process for troubleshooting spark and fuel issues? Thanks for any help, Mark.
Well, it's really hard to tell, but I was assuming intake, could be wrong though. Maybe you could address both scenarios.:)
   / Fuel leaking around manifold #4
Wet stacking from the exhaust side would be a mixture of water from combustion, partly burned fuel and lube oil that has slobbered past the rings or past the valve guides.
Does the temperature gauge reach 195F ?
When was the last time Old Blue was taken out and work hard at full throttle and at full power continuously for 2+ hours ?
This "wet stacking" only occurs at initial start up after being down for 1-2 wks as far as I know. Temp seems to get pretty high, usually pretty close to red on the gauge. Course who knows if the gauge is right. I've had it out brushhogging and/or disking a couple times in the last month or so. Usually at around 1500(+/-) rpms. As stated in my op it starts running rough after 45-60minutes or so and I usually just stop at that point.
Could this be a float issue?
There is no fuel pump(gravity fed). What's the best way to check the coil?
Hose Reel (A55758)
Hose Reel (A55758)
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
Towable arrow board (A55973)
Towable arrow...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
