Fuel leak on Stihl leaf blower.
/ Fuel leak on Stihl leaf blower. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
Stihl BG86 leaf blower and there is a slight fuel leak. It’s bad enough it needs fixed. If I take the air cleaner off it looks like fuel is just running out of the carb. Any ideas or common cause?
I think I found it, some kind of fuel line. It comes out of the top of the fuel tank and goes to the carb, there are two of them. One was leaking. I’m not sure if it has a siphon effect or with a warming day it pressurizes a little.
/ Fuel leak on Stihl leaf blower. #3
Yep, pressure is the culprit. I have weed eater that required fuel line replacement. It's leaked around the line an hole in tank ever since when fuel temperature rises.
/ Fuel leak on Stihl leaf blower. #4
Stihl should have a fuel line kit for that model blower. Probably not inexpensive but if not the correct size tube will just leak again and cheap materials will either get brittle or soften- turn to mush.
2007 International CE200 School Bus (A64194)
2007 International...
JOHN DEERE 1705 - 6R36" VACUUM PLANTER (A64278)
JOHN DEERE 1705 -...
2015 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2015 SolarTech...
2022 JOHN DEERE 17G EXCAVATOR (A63276)
2022 JOHN DEERE...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
