Fuel issue
/ Fuel issue #1
ALKY
bedford co. pa
tym 233hst
233tym Tractor has not run in years. Replaced fuel filter, pump, and injectors. Problem is it only runs smooth with #2 injection line cracked loose. Tighten it. It stalls. Foam is coming out. Ran fine for several minutes, tighten line it stalls. Any suggestions?
Assuming it's in the injection pump.
/ Fuel issue #2
I would start with the injectors. If the other two are getting fuel in the correct amourt to run, than I doubt it is the pump. The pump is simply a cam with some followers which are the pump cylinders.
Check around for Mitsubishi S3L parts. there is a guy offering the complete set of three on eBay For around $50.
The lowest I have seen for a used fuel pump is $400.
/ Fuel issue #4
It’s very possible that the injector is stuck open.. & when u tighten it, the compression is blowing back into the pump, shutting it down..
A very easy test would be to swap it to another cylinder and see if the problem follows the injector..
I can redo those injectors for u..
2022 John Deere 3025E (A64911)
2022 John Deere...
2015 John Deere 323E Compact Track Loader Skid Steer (A66734)
2015 John Deere...
2013 International Pro Star (A64911)
2013 International...
2000 CATERPILLAR 322BL EXCAVATOR (A65053)
2000 CATERPILLAR...
2021 Komatsu PC210L Hydraulic Excavator (A66734)
2021 Komatsu...
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
