Fuel issue
/ Fuel issue #1
ALKY
bedford co. pa
tym 233hst
233tym Tractor has not run in years. Replaced fuel filter, pump, and injectors. Problem is it only runs smooth with #2 injection line cracked loose. Tighten it. It stalls. Foam is coming out. Ran fine for several minutes, tighten line it stalls. Any suggestions?
Assuming it's in the injection pump.
/ Fuel issue #2
I would start with the injectors. If the other two are getting fuel in the correct amourt to run, than I doubt it is the pump. The pump is simply a cam with some followers which are the pump cylinders.
Check around for Mitsubishi S3L parts. there is a guy offering the complete set of three on eBay For around $50.
The lowest I have seen for a used fuel pump is $400.
/ Fuel issue #4
It’s very possible that the injector is stuck open.. & when u tighten it, the compression is blowing back into the pump, shutting it down..
A very easy test would be to swap it to another cylinder and see if the problem follows the injector..
I can redo those injectors for u..
2017 GMC Sierra 2500 HD 4x4 Crew Cab SpaceKap Service Truck (A66736)
2017 GMC Sierra...
2004 INTERNATIONAL 4300 4X2 S/A  UTILITY BODY (A66091)
2004 INTERNATIONAL...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
Hoelscher 110 Bale Grapple (A64126)
Hoelscher 110 Bale...
2013 Ford F-150 Crew Cab Pickup Truck (A66736)
2013 Ford F-150...
2007 Freightliner M2 106 Pothole Patcher Truck (A66736)
2007 Freightliner...
