Fuel Injectors
   / Fuel Injectors #1
eddieirvine
Indiana
Kubota L 3940
How is the best way to clean fuel Injectors, i do not have an issue as far as i know but curious if it is an easy job or needed? Also injector cleaner from time to time work ok?
   / Fuel Injectors #2
I've never seen a bad injector. I worked at a tractor dealership and used a tester and never seen a bad one. We have six tractors here. Never an injector problem. Oldest is a Fordson Power Major 1958. I have seen it on trucks from having a chip with the fuel turned up too high. Weakens the springs in injectors and they over fuel when it is put back to normal. But as far as run of the mill injector problems, no.
   / Fuel Injectors #3
Agreed-normally not needed.
I have cured the occasional "sick" diesel with a quart of ATF in the fuel tank.
Good Luck!
   / Fuel Injectors #4
Run good quality fuel and change the filter on schedule.
   / Fuel Injectors #5
My impression is the best way to deal with injectors when you are not experiencing a problem, is by leaving them alone.
Is injector cleaner available for diesel engines? I suppose so, there are so many of them in operation...Snake oil or beneficial, have no way to know at my end.
   / Fuel Injectors
Thanks guys good info for sure, My way of thinking, If it ain't broke leave it alone LOL
2013 Dodge Journey SXT SUV (A50324)
2013 Dodge Journey...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
2017 John Deere Gator TS Utility Cart (A50322)
2017 John Deere...
John Deere 652R (A50121)
John Deere 652R...
KJ 20'x30' Metal Garage (A50121)
KJ 20'x30' Metal...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
