Fuel Injectors
/ Fuel Injectors #1
eddieirvine
Indiana
Kubota L 3940
How is the best way to clean fuel Injectors, i do not have an issue as far as i know but curious if it is an easy job or needed? Also injector cleaner from time to time work ok?
/ Fuel Injectors #2
I've never seen a bad injector. I worked at a tractor dealership and used a tester and never seen a bad one. We have six tractors here. Never an injector problem. Oldest is a Fordson Power Major 1958. I have seen it on trucks from having a chip with the fuel turned up too high. Weakens the springs in injectors and they over fuel when it is put back to normal. But as far as run of the mill injector problems, no.
/ Fuel Injectors #3
Agreed-normally not needed.
I have cured the occasional "sick" diesel with a quart of ATF in the fuel tank.
Good Luck!
/ Fuel Injectors #5
My impression is the best way to deal with injectors when you are not experiencing a problem, is by leaving them alone.
Is injector cleaner available for diesel engines? I suppose so, there are so many of them in operation...Snake oil or beneficial, have no way to know at my end.
/ Fuel Injectors
Thanks guys good info for sure, My way of thinking, If it ain't broke leave it alone LOL
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 FREIGHTLINER CASCADIA TANDEM MID ROOF (A59906)
2017 FREIGHTLINER...
Coats 5060AX Rim Clamp (A61307)
Coats 5060AX Rim...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
