Fuel Injector Pump Replacement
/ Fuel Injector Pump Replacement #1
ebuildersinc
Waco, TX
JD 5085M
I recently purchased a used 2008 JD 5085M with cab & loader. Machine had 850 hours when I purchased in December 2013. Personally completed full service on tractor at 900 hrs. Problem arose while pulling fertilizer buggy this past week - loss of power, tach surging, wouldn't climb an incline, puffing white/blue smoke, then finally died. I drained water separators, primed, then tractor would start and rev up nicely...for about 50 feet! I took into local JD dealership for troubleshooting and they returned with call today. As I expected a fuel system problem, they confirmed with saying it needed the fuel injector pump replaced. Quoted cost was around $2,350...$1700 for part, 650 labor.
My questions are:
1. Has anyone had any personal experience with this issue? If so, how was it resolved? Cost?
2. What is the difficulty level for novice like myself to replace?
3. Best place to purchase part? JD has to be the highest around...I could be wrong.
/ Fuel Injector Pump Replacement #2
900 hrs on an inj pump failure doesn't sound correct. What happened to the day of sending inj pump to fuel inj repair shop? Is that a thing of the past on the newer inj systems? There was a good fuel inj repair place in Waco but I can't think of their name at the moment. $650 sounds high to R&R an inj pump. Is the part they're stating to replace the inj pump or the rail? Is your servicing dealer Brazos Valley? This is the price listed for the pump RE543423 Fuel Injection Pump ADD 2,261.00 USD
/ Fuel Injector Pump Replacement #3
I'm not at all familiar with your J.D., however if it has a Yanmar engine, you should have access to a rblt pump. Get the numbers off the pump, and google for rblt diesel injector pumps. We recently bought a set of rblt injectors and a rblt pump from an outfit in Millington Tenn. Beautiful merchandise and excellent people to deal with. Don't know if they do Ag pumps or not, but just about any good diesel shop can. I know everglades diesel in Ft. Lauderdale can, they did the one on my pettibone forklift.
/ Fuel Injector Pump Replacement #4
ebuildersinc
I discussed your tractor problems with a JD technician(friend of mine) and he stated less than 3 hrs to R&R inj pump. He stated 1st thing he would do is replace fuel hose from tank to inj pump as the fuel hose on JD tractors has a looonng history of failures. He also stated he thought that if inj pump was the problem it could be repaired instead of replaced.
/ Fuel Injector Pump Replacement #5
This not a Yanmar engine, it's an 85HP JD engine
ebuildersinc
As TxJim states, start with the easier/cheaper things. Make sure the fuel tank is clean, replace all fuel hoses, make sure fuel filters are properly installed (no missing/damaged gaskets/o-rings). Injector pump failure after only 900hours? Did they say how they determined it was the injector pump? Might want to call Deere corporate for help.
Injector pump should last more than 900 hours.
I have called a local tractor mechanic but have not heard back after two messages. Plan on calling JD in the morning to find out what led them to the inj pump. Will call JD corp after if local shop is sure it's the inj pump to see if they have a secret warranty and if not, to mainly voice my utter disappointment.
Well I actually received a call from local dealer (Brazos Valley Equipment) before I got a chance chance to call them. They said they have ordered the part, should have replaced by Wednesday next week, and IT WILL BE WARRANTIED under an emissions warranty. Made my day and impressed they checked into it before I called.
Will report after receive tractor back next week. Thanks to all for your help!
/ Fuel Injector Pump Replacement #9
Sounds like a good deal for you.
/ Fuel Injector Pump Replacement #10
cool.... that saved you a fortune.
/ Fuel Injector Pump Replacement #11
Good News! Did they say how long the emissions warranty was?
Good news - Bad news - Good news
As promised, the dealer called saying the tractor was ready. It turned out that my friend purchased a new hay cutter so I had to road the tractor from the dealer to my friend's barn with the new cutter, drop off, pick up a bale of hay & hook up to his cultipacker, then road to my place two miles away. Not one minute into the drive from the dealer I noticed the engine surged a little and I said to myself...they didn't fix it! This is at 4:45pm today. A half mile from friend's place tractor loses all power, will not climb a slight incline, puffs white/blue smoke, etc,,etc...I'm pissed. I call dealer, they send tech to find me...(5:00). Tech follows me at idle speed until I jump out of the tractor cussing that I'm gonna put a bullet into the **** thing. Tech drives tractor - learns what i've been saying the whole time. (By the way, the tech that is here now is a veteran with the tech that worked on the tractor at the dealer). To shorten the saga....I limp to my place and after fiddling with several things, he drains the tank and cleans the filter at the fuel intake line....THAT'S IT!!!! ; WORKS GREAT!!!... Field now ready for sprigs.
So the tractor has a new fuel injection pump courtesy of warranty - wrongly diagnosed but...new
Oh, and in addition... I purchased a hydraulic ripper box blade from dealer a month ago. Used it once but could not get the blade to adjust correctly. In order for it to "cut" correctly it would not raise up enough to back up! (I've dealt with box blades for 25 years...no dummy) That was a month ago I dropped off the tractor with blade for dealer to figure out. They did...Turns out the linkage plate needed turned over to drop linkage arm holes down in order to work properly. It was plain in the manual...wish I had one as the previous owner did not give me one. Just a tidbit.
All in all...very happy with Brazos Valley Equipment. They were very courteous and responsive.
/ Fuel Injector Pump Replacement #13
I'm glad you got it going. So if I'm understanding you correctly the problem was a clogged fuel filter not inj pump??
/ Fuel Injector Pump Replacement #14
No offense to the dealer but they didn't do a proper diagnosis, very last item to look at after getting junk in filters is injection pump replacement.
The problem was the fuel line in the tank. It apparently has a screen on the intake end that was clogged.
I agree that it was a poor diagnosis but I have mellowed with age so I'm happy.
/ Fuel Injector Pump Replacement #16
I have a 2013 5075M. I had a similar experience at less than 50 hrs, except my engine didn't die, sputter or smoke. I would throw a code occasionally when I hit 2200 RPM (540 PTO speed) with the "!" cautionary exclamation warning and beeping. I called the dealer and the tech came out and pulled the code. The code was low fuel pressure. He said that occasionally, plastic shavings from the milling/drilling on the fuel tank from manufacturing may be left in the tank will collect in the line and choke off the fuel. He asked me to drain the fuel for later use being careful to strain it with a filter. He then he cleaned the tank, lines and replaced the fuel filter (warranty of course) and the problem has never resurfaced. I am surprised it took yours 800 hours to show up. Sorry I didn't catch your thread earlier or I would have mentioned my experience and may have saved you a bit of frustration.
/ Fuel Injector Pump Replacement #17
ya but you wouldnt have been if you had to PAY for the injector pump.......glad it worked out
/ Fuel Injector Pump Replacement #18
that saved a pile of $$$ for sure, are they replacing the pump or supplying only, either way, you did well.
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
2020 Ford Ecosport 4WD SUV (A59231)
2020 Ford Ecosport...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A59230)
2016 Peterbilt 579...
78" BOX BLADE (A60430)
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
